HAVE PUT A SHEET OF PAPER IN PRINTER AND ITS JAMMED ALSO WHEN I WANT TO PRINT OUT MY WORK IT DOES NOT WORK WHY IS THIS SO I GO THROUGH THINGS TO DO ITAND IT DOES NOT WORK I AM NEW AT THIS SO CAN YOU WHEN YOU GO THROUGH THIS TO DO IT AND EXPLAIN IN SIMPLE TERMS WHEN I FIRST STARTED TO PRINT IT WAS DOING IT OKAY AS I'M DOING A COURSE ON PRACTICAL COMPUTING COURSE AND I HAVE TO PRINT
hardrocko
  • 1476 Answers
SOURCE: Printer Jamming with too much paper
This is a common problem with HP printers. I can't say that I have worked on a Dell printer but they probably use the same or similar mechanism to pull paper from the tray. The problem is a worn separator pad which costs about $5.00. The real cost will be in getting to it. It is not something for a novice to try. Better take your unit to a reliable repair shop.
Posted on Jun 22, 2006
Mix-it-up
  • 832 Answers
SOURCE: Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Posted on Sep 09, 2007
pagebor
  • 2785 Answers
SOURCE: Continual problem with paper jam
try with other manufacturer's paper, you can try by reinstalling the drivers
if the problem persist then your printer needs to be serviced
Posted on May 31, 2008
SOURCE: Paper Jam
No still jammed will contact the shop I purchased it from or ask the IT people I deal with at work if they have solution. Thanks
Posted on Dec 02, 2008
SOURCE: Printer Jam - when i put a sheet of Avery labels, printer jams
I had the same problem and was able to get around it by changing my paper setting within the Printer Properties page from "Plain Paper" to "Inkjet Paper."  Hope this helps!
Posted on Feb 12, 2009
Paper jammed
Hi Good day!!!
Here are some steps to remove paper jam
1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
After printing a sheet of labels, the printer jams with paper, and I can release same thru the rear door. How can I eleviate this problem ?
put the paper fomat correct type and try to print, if the same thing try to clean the paper path properly
Oct 26, 2010 | Brother HL-2040 Laser Printer
11x17 paper jams from drawer - will not feed from sheet bypass
Check to see if the actuator arm is stuck in the bypass tray,therefore not seeing the paper and be sure the side guides are up against the paper. If that doesn't work and you have 2 cassette cavaties put the 11 X 17 where the other tray is . Hope it works for you.
Apr 09, 2010 | Office Equipment & Supplies
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Paper Jam C84
Was the printer feeding multiple sheets at the same time, so that the sheer thickness of the wad caused the jam? If so, look into the slot where you load paper (this is called the automatic sheet feeder or ASF). You should see a small roller with a rubber coating. This is what pulls the sheets into the printer. Put one sheet of paper into the ASF and do a print. The Windows test print facility is convenient for this: start-control panel-printer and faxes, then right click your printer icon and select properties, then test print). If this works OK, put two pages into the ASF, then three etc. Observe what happens. If at some point more than one page is pulled in, it infers that the ASF is not working properly, in which case you will need to consult a technician (or have a go yourself at dismantling the printer). If the one-two-three-four etc page test doesn't produce a multiple feed, all it probably means, is that static electricity is holding the sheets tightly together. Make sure when you put a wad of paper into the ASF it has been fanned.
Report back on what you find, or if you have any queries on the above.
Jan 22, 2009 | Epson Stylus C84 InkJet Printer
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Hp psc 1315 paper jam
2.
3.
4.
5.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam issue
I finally fixed the problem by running two sheets of heavy card stock through at the same time.  With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on.  When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor.  I previously found that only one sheet at a time did't work.
Nov 26, 2007 | Canon PIXMA MP460 All-In-One InkJet...
15 people viewed this question
jasbo
jasbo
