Question about Olympus FE-230 Digital Camera
When power is turned on the card setup screen pops up. The only 2 options are to power off or format. If I select format, the pictures will be erased if yes is selected.
  • 10,594 Answers
Memory card seems imbalanced due to some reason and can only be corrected by formatting as advised in camera pop up.
Of course all picture files will be deleted if card is formatted. Try to put card in card reader and back up files in computer.
Posted on Sep 11, 2009
How do I format the sd card in the DMC_ZS7
Welcome to FixYa.
To format the SD card, select [Format] from the [Setup] menu
To bring up the Menu option, press the Menu/Set button. Then select [Setup] and then select [FORMAT]. Then choose Yes to format the card.
Please note:
This requires a sufficiently charged battery, or an AC adaptor (optional) and DC coupler (optional). When
formatting the built-in memory, remove the cards.
(Only inserted card will be formatted if present; built-in memory will be formatted if no card is inserted.)
• Always format cards with this camera.
• All picture data including protected pictures will be deleted.
• Do not turn off power or perform other operations during formatting.
Thanks for using FixYa.
Feb 11, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Feb 20, 2009 | Fuji FinePix S700 Digital Camera
3-350 card setup
Formatting the card will erase all images. dont do that until you have them backed up on a cd or your hard drive
Oct 19, 2008 | Olympus Camedia C-350 Digital Camera
Picture card
You can buy a cheap multi card reader at an office supply store, Best Buy, a computer store or a photographic supply. Use the card reader to read your memory card from your computer
Feb 15, 2008 | Fuji FinePix 1400 Zoom Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Format CF card
In general it is pretty hard to recover photos on a compact flash card once it has been erased and overwritten. You can just erase and take pictures over it many timesand this will pretty much take care of the problem.
You can also use an external card reader and load videos, pictures, data, etc. several times and this should make recovering your previous photos almost impossible.
You can try another option which does what the 1st two suggestions did (except it is automated) and use a commercial software program. Here is one such program. http://www.photorescue.net/downloadcardwiper.htm
Oct 24, 2007 | Canon PowerShot A80 Digital Camera
Deleting pictures from camera....
press menu
go to setup
scroll down to the second option: memory stick tool
go to format
re-set the format to "ok" even if it says "ok" already
press ok to all dad in memory stick will be erased, ready?
and all the pics will be deleted. thats the problem with this camera, everything is good except trying to figure out how to delete them all!!! ughh
May 30, 2007 | Sakar 81480 Digital Camera
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Olympus FE-230 Digital Camera Logo
107 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
