Question about Bosch 18V Brute Tough Litheon Hammer Drill/Driver 17618-01
I just purchased a Bosch 18 volt cordless drill and one of the batteries will not operate to drill. It shows that it is fully charged. How can I check the battery?
    Problem Solver:
  • 16 Answers
Just call 888-919-7272 and you can get it replaced.
Posted on Mar 10, 2010
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
How to remove necessary parts from Bosch PSR 12 cordless drill to recharge the battery?
You shouldn't have to remove any parts, except the battery itself, to charge the PSR12. I did find a breakdown of your drill that shows a 'Battery Retaining Clip' that is a heavy, u-shaped wire that goes into the front of the housing section just above the battery. It may have to be removed to get the battery out.
Nov 25, 2012 | Bosch 12 Volt Cordless Drill
Will 18 volt black & decker charger over charge battery
Hello Howard, There are two different kind of cordless drill chargers. One is a smart charger that will not overcharge your battery. It usually has a stand alone base that the battery plugs into and sometimes may have a red and/or a green light to let you know it is charged. This charger will stop charging when the battery is fully charged after an hour or less. The other one is a dumb charger that can overcharge your battery if left on the charger too long. This charger usually has a square or rectangular transformer that plugs directly into your wall receptacle. This charger may take up to eight hours to fully charge your battery and will continue to charge until you unplug it.
Oct 04, 2011 | Black & Decker & Cordless Drill
Turn it on-battery fully charged, worked a week ago, now when I snap it in nothing happens, reverse or forward...am i forgetting something?
Check the conections on the battery and drill aren't tarnished.
This is a common problem which prevents drills from operating.
The contacts can be cleaned with very fine sandpaper.Don't rub too hard or you will remove the chrome plating on the contacts.
Feb 03, 2011 | Bosch 12 Volt Cordless Drill
Drill will not operate. I charged batteries but still will not operate. Is there an overload reset?
Just try to buy a new battery and test.If persist,change the charger. Bet the bats are dead.
Nov 10, 2010 | Hitachi DV18DVC 18V Cordless Hammer Drill
Green light stays on when charging the red light does not come on
The battery is dead, and the charger will not not charge it. You need to purchase a new battery.
Apr 08, 2010 | Black & Decker 18 Volt Cordless Drill...
Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Jul 15, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Bosch 18V Brute Tough Litheon Hammer Drill/Driver 17618-01 Logo
165 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
