Question about Panasonic PV-DV402 Mini DV Digital Camcorder
Panasonic PV-DV402 with Windows Vista
My Panasonic PV-DV402 camcorder is not compatible with windows vista. What can I do to fix the problem?
  • 1 more comment
  • funso Jan 29, 2008
    i need further help on this problem.
  • funso Jan 31, 2008
    any link to a free XP? How do I uninstall Vista without messing up my whole system?
  • funso Feb 09, 2008
    I guess I have to either buy a new camera or forget about windows vista.
    Master:
  • 788 Answers
That is the sad truth about Vista, manufacturers are either slow at providing support for older equipement or ignoring them altogether. Panasonic has not upgraded the software for that camera since 2003. You best solution would be to create a second partition on your computer and install Windows XP in a dual boot configuration, but that would cause problems as your should do it the other way around (install XP then Vista). Or you could buy a cheap XP computer (a used one or value one). Or you could upgrade to a newer camera.
Although you may luck out downloading software for a newer camera from panasonic, maybe this driver might work: ftp://ftp.panasonic.com/pub/Panasonic/Drivers/capture/ComMass.zip
Does the camera have firewire? Did you try connecting it that was?
Posted on Jan 29, 2008
  • 1 more comment
  • Dean Joly
    Dean Joly Jan 29, 2008
    What is it that you need further help on?
  • Dean Joly
    Dean Joly Jan 31, 2008
    Nothing is free, but XP can be had for under $70 these days if not cheaper. Your system probably came with recovery DVDs, make sure you have those before doing anything since that is how you would return to Vista once you upgrade to a newer camera. Then backup all your data to DVDs or an external or secondary hard drive. Once you are ready then load XP according to the instructions (boot to the CD and follow the on screen instructions). Do all the Windows updates and get all the missing drivers in device manager. It could be tricky to get all your drivers since your system was probably designed for Vista but if you go to the websites of the individual device manufacturers you should be able to find network, sound, and video drivers for XP. Good luck!
  • Dean Joly
    Dean Joly Feb 11, 2008
    Those are you best bets, unfortunately.
    Sergeant:
  • 226 Answers
PV-DV402 driver
Developer: Panasonic
Version: 5.15.0
System: Windows XP,Windows 2000 SP4,Windows 2000 SP3,Windows NT SP4,Windows 2000,Windows 2000 SP2,Windows 98 SE,Windows 95,Windows NT SP2,Windows 98,Windows NT,Windows 3.11,Windows ME
License: shareware
http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=CamcorderDownloads
URL
Supported software
Windows NT SP1 PV-DV402 driver
Windows NT SP2 PV-DV402 driver
Windows 2000 SP3 PV-DV402 driver utility
Windows NT PV-DV402 controller
Windows 2000 SP4 PV-DV402 codec
Windows 98 SE PV-DV402 driver utility
Windows NT SP4 PV-DV402 zip
Windows 95 PV-DV402 controller
DOS PV-DV402 pci controller
Windows Vista PV-DV402 pci controller
Windows NT SP1 PV-DV402 driver utility
Windows 2000 PV-DV402 driver utility
Windows 2000 SP2 PV-DV402 codec
DOS PV-DV402 driver utility
Windows 2000 PV-DV402 controller
  • earl llanera
    earl llanera Jan 29, 2008
    did you download the link? and install the driver
    Genius:
  • 1,665 Answers
Have a look. i continue searching fo compatible driver.
http://www.xpvistasite.com/p/
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jan 29, 2008
    Kleanthis Mavropoulos Jan 31, 2008
    You can't go to WIN XP if WIN vista is installed. A way to use again WinXP at the same PC is to use another hard disk as "master" and do windows XP installation on it. Depending on your Bios features you can select the mode from which hard disk PC starts ,so when you want to use your camcorder select to boot from "XP installed disk" otherwise boot from your current "Vista Installed" disk. I hope your computer is a desktop and there is space for two Hard disks to be synhronous connected.
    The other way is to low format your HD and install a new fresh Win XP on this.
  • 146 Answers
    Guru:
  • 1,894 Answers
Yes panasonic is yet to release its software compatiable to vista.
it will be coming in few months or so. but i suggest you to install another operating system else use some friends system for transfering files to your system.
that will be better i guess.
  • 4 more comments
  • dewan nafees ahmed Jan 29, 2008
    hey hey.. i said you that right..
    your model in specific is not compatiable with vista..
    so you have no choice that you should opt for another operating system. XP prof is avilable in torrentz for free of cost. you can download it and install it in your system,., by this way your system can detect the device..
    and hence please note brother.. your device in specific has not software compatiable for vista.. so dont dream for craking it and creating a new software..
    we experts here can suggest you a solution. cant make a software for you right..
    and hence start your process of installing XP in your system.. that is the only fix for you..
    i also bet you.. XP is 100 times better than VISTA... ....
  • dewan nafees ahmed Jan 31, 2008
    you can download it from torrentz.. mnay free XP copies are there in torrentz..
    make yu wil have to loose any one partition of your system to install XP in it.. and so back up the files in a drive and move ahead
  • dewan nafees ahmed Feb 05, 2008
    did the solution work?
  • dewan nafees ahmed Feb 07, 2008
    what happened?
  • dewan nafees ahmed Feb 08, 2008
    has this thread been closed?
  • dewan nafees ahmed Feb 09, 2008
    @machine
    neither me nor any of my friends have spent a penny for getting windows XP or any of the sotware...we get all of them in torrentz..
    torrentz is not illegal.. but the material what you get in is mostly illlegal. and hence only i dint give any download link here.. because we are allowed to give illegal links..
    if i have to pay money for getting XP i would have lost all my dads property in getting all versions of XP itself..
    everything is at ur finger tips man.. you just need to search it out...try making money.. dont stop spending money.. :)
  • 871 Answers
Hi there
you can try and check panasonics home site for compatibility issues regard there products to windows vista.
hope this would resolved your problem.
  • earl norman llanera
    earl norman llanera Jan 29, 2008
    they usually give new drivers for your product tobecome comaptible with vista.
Hello: I have a Panasonic PV-DV202-K Digital Video Camcorder. Is there a driver that I can download that works with windows 7...Robert
By your phrasing I am assuming you have a driver for a legacy OS such as windows 9X/2K/XP/Vista?
You can use these drivers in windows 7, install them like you would any other driver. You can also run things in compatability mode.
May 16, 2011 | Panasonic Computers & Internet
Palmcorder PV-DV402 doesn't work with tape inserted
Have you tried with different tapes ? Could be that this one is binding inside, and the camcorder cannot move it. Will it fast forward and rewind ?
Jul 22, 2017 | Panasonic PV-DV402 Mini DV Digital...
My windows 7 laptop does not recognize my Panasonic Mini DV Camcorder PV-GS39 and therefore cannot capture video any ideas?
You are going to have to check that your firewire is being seen by windows 7 first of all. If not you will need to rectify that.
When you do get it to recognize it, here is a link for an update to the program that came with your camcorder for it to work with Windows Vista but it should also work for Windows 7.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D#ts
Hope this helps,
Mar 24, 2010 | Panasonic PV-GS39 Mini DV Digital...
Download software for windows vista
Pinnacle Studio works with Vista as well as your camera.
www.pinnaclesys.com
Sep 03, 2008 | Panasonic PV-GS19 Mini DV Digital...
How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
Aug 24, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
I am unable to connect my Panasonic PV GS150 handycam and Vista business edition running laptop using a USB cable. Do I need driver S/W?
You will need to install the USB driver from your software(disc) to your vista.
and make sure the computer is recognizing your camera, check under control panel and device managers list if your product is listed under imaging devices, but chances are you might be having compatibility issues since it doesnt have an updater for Vista, hope this help. pls dont forget to rate. Thanks!!
Apr 09, 2008 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-Gs85 importing issues
Yes, the XP driver would not work with Vista. No solution on the Panasonic website.
Feb 28, 2008 | Panasonic PV-GS180 Mini DV Digital...
PV-GS31 often disconnects from vista
I called Panasonic directly today & asked about the Vista driver for the GS31. No such driver exists, but they are trying to develop a driver specifically for Vista users of this camcorder. Finally the mystery is correctly answered & solved for us Vista owners! woooohooo !
Nov 17, 2007 | Panasonic PV-GS31 Mini DV Digital...
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
See all Panasonic PV-DV402 Mini DV Digital Camcorder Questions
Panasonic PV-DV402 Mini DV Digital Camcorder Logo
431 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
