It requires about 10 minutes for the picture to show up after the unit is turned on, and it has a very fuzzy screen much of the time.I requested assisance from COX my provider and they said this problem is not with in their capabilities.
I purchased this unit at Sears in Baton Rouge, La.I have 2 Samung televisions and one Samsung Computrer Lazer printer which is my second unit.
My address is 11931 Parkmeadow Ave. Baton Rouge, L.
Phone is (225) 291-8405
Please Advise,
Fred Hughes
there is a reading lens in the unit.its called the "EYE" of the unit.if the reading lens is weak and dusty.this problem occurs.because the reading lens is weak it takes time to show up the picture and because its dusty it shows fuzzy picture.
the internal lens first has to be cleaned and checked.if still the same problem the lens has to be replaced.this is common problem faced by many users.but replacing the lens solves the problem.for getting it replaced you can take it to the local electronics repair center.this will help.
thanks.please do rate the solution.thank you for using fixya.
Tried all the cable remote codes to operate the Samsung DVD-VR 357. Which code works with comcast...
(More)
Tried all the cable remote codes to operate the Samsung DVD-VR 357. Which code works with comcast remote control? Thanks
I recorded a VHS to DVD-R. Regarding the title list, I entered Title 1 and want to know how to add...
(More)
I recorded a VHS to DVD-R. Regarding the title list, I entered Title 1 and want to know how to add other titles.
Can you record from an older sharp video recorder (vl- a45) to the samsung vr-357? I would like to...
(More)
Can you record from an older sharp video recorder (vl- a45) to the samsung vr-357? I would like to record fronm the older camera to a dvd, but am not having any luck. Your expertise, or suggestions, would be greatly appreciated.
Have a 2 year old Samsung DVD-VR357 turned it on recently it accepted my DVD and then lost power,...
(More)
Have a 2 year old Samsung DVD-VR357 turned it on recently it accepted my DVD and then lost power, check plug-in was plugged in, but will not turn on. HELP.
