Question about Whirlpool Washing Machines
Model WTW6600SW2 makes a clunking noise during the wash cycle
  • 1 more comment
  • marsha_mille Sep 11, 2009
    This machine is only 18 months old. My husband thinks it could be the drive motor.
    I will try this over the weekend and get back to you on Monday thanks!
  • marsha_mille Sep 14, 2009
    I tried running a cycle without any clothes and there wasn't any clunking noise and it seems to happen sporadically when washing normally. More often with heavier loads.
    Thanks, Marsha
  • 854 Answers
Check the coupler between the motor and transmission. Noises during the agition or spin cycle are indications of a bad coupler. This is the inexpensive part. It could also be the transmission.
Posted on Sep 15, 2009
    President:
  • 2,777 Answers
Trying running the machine while it is empty and listen for the clunking then as well. Does it happen then? Please let me know, it may be something is off balance inside the unit and needs to be re-aligned. However it could be just an uneven load causing it to bump into things as it spins. I assume it does this every time with clothes in there?
Thanks
Tim
Posted on Sep 11, 2009
  • Tim Grayson
    Tim Grayson Sep 11, 2009
    No worries, definitely check it out and let me know. Of course make sure you don't use any soap or anything like that in it when you run it empty. It could definitely be the motor as your husband suspects, but the info you provide on Monday will help confirm.
    Thanks
    Tim
  • Whirlpool Master
  • 17,970 Answers
Most likly its the drive belt at the bottom of the washer. Get accessto the bottom from either the front or the back whichever panel isremovable take the old belt out get a replacement and install.
For parts, check HERE
Good luck.
Posted on Sep 14, 2009
  • 601 Answers
The bearing under the tub has lost it's grease.Check any signs of grease spatter marks around the perimeter of the machine inside.
If not the problem was with the pump. To check this remove the pump from the motor just to see if the noise was coming from the pump.If It was then pulled the pump off the hoses to get a better look at it, and check for any debris in it.
Hope this helps
Thanks
Smith.
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
