Question about Panasonic ET-LA785 Projector Lamp for PT-L785
Need to reset the lamp hours on a Panasonic LA785
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
  • 159 Answers
SOURCE: reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Posted on Apr 08, 2009
dsacco86
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
  • 3 Answers
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Posted on Jul 25, 2009
  • 9 Answers
SOURCE: Replaced lamp bulb on panasonic pt52lcx66, reset
Pull the lamp out and install again and reset with the orignal remote control. (not a universal)
Posted on Jun 02, 2010
How do you reset the lamp hours on a Panasonic PT-61LCX66-K
There probably is a service manual you can find on line to help you with how to reset the lamp hours.
http://www.manualowl.com/m/Panasonic/PT52LCX66/Manual/289575
Nov 11, 2014 | Panasonic Televison & Video
RESET THE LAMP HOURS OF PT-LB60EA
Go to menu > option > lamp hours. Then press enter on the Lamp Hours for 5 seconds. A new option will pop out asking to reset lamp
Dec 14, 2011 | Panasonic Projector Lamp for PT-LB60,...
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
I need to lamp hour meter reset
HERE IS THE RESET LAMP TIMER INSTRUCTION
http://www.fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!!!
Oct 12, 2010 | Panasonic PT-52LCX65 44" HDTV
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic HDTV 1080i Lamp out Panasonic 1080i 42" HDTV - - saying "lamp needs to be replaced, reset lamp" - - what does this mean and how do I fix it??
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Jun 01, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
How do you reset lamp hours back to zero on a Panasonic PT-D4000U projector?
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
Apr 13, 2009 | Panasonic PT-D4000U Projector
Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Panasonic ET-LA785 Projector Lamp for PT-L785 Logo
56 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
