Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
WILL NOT MOVE, AT FIRST IT WENT A FEW INCHES BACK AND FORTH NOW NOTHING?
  • mavessel Sep 16, 2009
    I don't quite understand, tape what end to the wet and dry vac??? where is there an open end on the robo?
    Top Expert:
  • Smartpool Master
  • 76,630 Answers
Is the motor running? if yes the infrared sensor has failed, without any location input the mower will not move, this is a fail safe function, this can also be caused by a defective control circuit board.
Posted on Sep 16, 2009
  • 854 Answers
Take a wet-vac and tape the end to your cleaner hose Turn it on while the cleaner is out of the water for about a minute. Then put it in the water "still running" and let it go for another 30 seconds.. Untape the hose from the vac and try it out.
check for a clog in the system.
Posted on Sep 15, 2009
Why does garage door opener only move a few inches?
Check the spring above the door, mine would go up a couple of inches and we found that the spring had broke.
May 16, 2014 | Sears Craftsman LiftMaster Chamberlain...
2006 dfdwg with engen off and in gear it will roll back and forth several inches when it should not move at all
No, it SHOULD move an inch or two.
This is due to the clearance between the transmission gears, the chain slack, etc.
Usually I have to rock my bikes back and forth a little so I can find the spot in between to relieve that loading on the transmission gears, so I can put it into neutral to start.
Aug 19, 2013 | 2006 Harley Davidson FXDWGI Dyna Wide...
I have not used my Robo Kleen for several years. It was in storage in the basement. I put it in the pool and at first only moved a couple of inches. I manually rotated the wheels and they are very...
try keep working the wheels, it might free up. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 11, 2013 | Smartpool Dolphin Robo - Kleen Above...
Steering goes back and forth while driving
check your tires you could have a split belt in one of the front ones
Dec 08, 2011 | 2002 Lincoln LS
I have a saturn sl2 i put a new tensioner pulley on it it work for about 5 miles then it started making a noise the tensioner pullley is moving bck and forth about a inch and the new belt is already...
well you replace the whole tensioner arm, which will have a new pulley on it. the spring in the arm goes bad, that means the pulley does little to nothing in keeping tension on the belt. the fact that the pulley moving back and forth tells you the spring is shot.
Apr 13, 2011 | 1996 Saturn SL
Won't print, makes a continuse whining sound while the "scanning" Bar moves back and forth approx. an inch?
It sounds like the main drive motor gear has cracked.
Can you please tell me the model number ? On a few of those products that is very common, and I could give you a part number.
If it is the machine I suspect, then it would be very easy to fix.
Jan 07, 2010 | Xerox Office Equipment & Supplies
Black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Jun 21, 2008 | Nikon Coolpix S4 Digital Camera
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
219 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
