Question about Samsung ML 1430 Laser Printer
Samsung ML 1430
The data light won't go off and it won't take print jobs from the computer
    Scholar:
  • 151 Answers
  1. You need to rotate the rubber band on the feeder roll to a fresh surface. Start by turning off the printer, disconnecting it from power & data feed.
  2. Remove the two screws from the back panel and press the small tabs to pull the back panel off.
  3. Open the front of the machine and remove the two screws that hold the top panel in place. Take note of how the sheet feeder sits in this assembly. The sheet feeder is not screwed in, but rather held in by the other pieces.
  4. Remove the toner cartridge and set aside.
  5. There are four screws that go through the metal plate now visible at the top. Leave the wires connected and remove these screws. Take note that there is a grounding cable that needs to be reconnected.
  6. You need to remove that top assembly, so take note of how the roller fits into the black tie rod that actually turns the roller. I found that lifting the unit up and sliding it to the right (as viewed from the back) disconnected the roller from the tie rod.
  7. Remove one screw from the roller pickup assembly and disassemble the roller.
  8. Note that one side of the rubber band is shinier than the other. This is the problem. Carefully work the rubber band off, rotate it 180 degrees and slide it back on to the roller.
  9. Reassemble and test
Posted on Dec 10, 2007
  • Chris Montano
    Chris Montano Dec 10, 2007
    Same source as ctf1800... We might have posted at the same time...
    President:
  • 4,402 Answers
Http://degenportnoy.blogspot.com/2006/10/samsung-ml-1430-wont-feed-paper.html
I cannot print from my Mac to a Samsung printer - and the Samsung web site does not have any printer drivers for this device on their web site. Any idea how to fix it?
Looks like that printer is not supported anymore. You can try downloading the driver for the newer model ML 1440 and see if that works:
ML 1440 drivers
Mar 01, 2011 | Samsung ML 1430 Laser Printer
Price of cartridge of samsung ML-1640 mono laser printer
Rs. 2800/- original carteige
Rs. 1200/- compitable cartridge
Nov 09, 2009 | Samsung Laser Multifunction Printer Toner...
The red light then all the other lights flash alternately- nothing will print
• Reset the printer by briefly turning the printer off and back on again.
• If the error persists, contact a service representative.
Sep 14, 2009 | Samsung ML 1430 Laser Printer
I have a Samsung ML-1430 printer. My laptop isn't acknowledging the printer. I'm connected with a USB. Can you help?
hi, did you get a driver cd with this? if so use that to install the drivers needed for your laptop to recognise this printer, also do you know what operating system you are using? isit Windows XP? or another?
Aug 04, 2009 | Samsung ML 1430 Laser Printer
Can you oil a samsung ml-1430 printer to make it stop squeaking
Yes, lubricate the chrome shaft with light weight oil.
Jul 30, 2009 | Office Equipment & Supplies
How can I print an envelop on a Samsung ML 1430
Put an envelope in the sheet feeder, and use "letters and mailings" option in MS word or whatever program you're using
Jul 26, 2009 | Office Equipment & Supplies
Paper jammimg in our ML 1430 Laser Printer
clean the roller opening the door at the backside of printer...................and if u want our technician support contract us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Samsung ML 1430 Laser Printer
Cannot print on new Macbook with Leopard Mac OS - need driver
I just upgraded to snow leopard and my previous driver was erased, so I did some digging around and found the right driver (it is not included even in the most recent GutenPrint software).
Look at the Global Samsung website - the US Samsung site does not support MacOS drivers.
http://www.samsung.com/download/FileView.aspx?cttfileid=213919&type=Printer&typecode=15&subtype=Laser+Printer&subtypecode=1501&model=ML-1430&filetype=DR&language=
Your OS should ask to install Rosetta to read the file (Zip), but then the install is quick and easy. The printer driver immediately showed up in the printer>setup>driver menu. Prints without a hitch.
Haven't booted my laptop into 64bit kernel, so I don't know if the driver is 64bit compatible - I expect not. Hope this helps.
May 31, 2009 | Samsung ML 1430 Laser Printer
How can I make my ML 1430 Samsung laser printer wireless
You need a device called a wireless print server. Some sources are www.tigerdirect.com or www.newegg.com, or you can check pricewatch.com, look for units being sold on eBay.
Feb 18, 2009 | Samsung ML 1430 Laser Printer
Samsung ML 1430 - won't print; paper light flashes
Tuesday, October 17, 2006 Samsung ML-1430 Won't Feed Paper My printer had stopped feeding paper reliably a while ago. This had reduced me to manually pushing each sheet of paper into the machine until the roller caught it. Which, in turn, often resulted in many explicatives directed towards said printer.
All in all I like the Samsung ML-1430, which has been discontinued. It was pretty inexpensive, the toner cartridges aren't too bad considering I really have gotten thousands of pages (at Staples, which has a wicked good customer loyalty program, IMHO).
However, after only two years, there is this feed problem. I found the answer in an Amazon posting (thank you brs for posting this). Here is the solution from there:
This repair took less than 20 minutes and I expect that it will last another two years of rather heavy usage.
BTW, brs on Amazon also provided a repair part number: JC72-00109A. However, searching on Samsung for this part yielded nothing. I suspect this is due to the machine being discontinued.
Have fun!
Posted by Peter Degen-Portnoy at 5:44 PM icon18_email.gif icon18_edit_allbkg.gif Labels: printer, solution, technology 18 comments:
Dec 07, 2007 | Samsung ML 1430 Laser Printer
Samsung ML 1430 Laser Printer Logo
152 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
