Question about HP W2338h 23 in. LCD TV
Monitor grays too dark
Monitor too dark. I already set it to the brightest possible..but my blacks are still way too black. Normally I am not able to tell...but when I design a graphic I can really see the difference. my grays are black.
  • trailgem Sep 11, 2009
    THANK YOU. I just bought this monitor last month. If I wouldn't be a designer I wouldn't notice that I am "
    missing" grays. Everything looks really good.
    I guess it's time to call HP. :)
  • HP Master
  • 19,396 Answers
That means that the inverter board is faulty and myst be replaced.
The inverter board is an high voltage board that supplies AC power to backlight system. when inverter is faulty, you will get an extremely dark picture.
Parts must be tested before replacement.
Posted on Sep 11, 2009
  • Ginko
    Ginko Sep 13, 2009
    you are welcome, inverter is not an expensive replacement.
    Please do not forget to leave feedback.
    thanks.
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Screen goes black after 3 seconds tried another monitor does the same thing
if already tried replacing with other monitor then the same problem so that was mean the cause is with in the source or PC unit.
Sep 21, 2012 | Elo Entuitive 1525L (Dark Gray) 15" LCD...
What should exposure compensation be set on
That depends on what you're taking a picture of. Normally, you'd want it on zero.
Use it if the exposure meter produces an exposure too light or too dark for the subject. The camera's meter is designed to render all scenes as a medium gray. If you take a picture of a white dog playing in the snow, the camera will try to render the scene as a medium gray. In this situation you want to use positive exposure compensation to render the scene brighter.
Conversely, if take a picture of a black cat sunning itself on a black car, the camera will again try to render the scene as a medium gray. In this case you want negative exposure compensation to darken the scene.
Jul 09, 2011 | Kodak EasyShare C143 Digital Camera
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Black spots on the screen
I think you should try going to the store and checking if your monitor is still under warrenty. From the description, I think it is beyond repair.
Jun 26, 2009 | Samsung Computers & Internet
Panasonic lumix fx 10
If ECONOMY is set to off in that case monitor (LCD) would be brightest, it should not be dark, it would be at lowest if you set it to LEVEL2. Monitor sub-menu in the setup menu gives you option to increase or decrease brightness of the monitor (LCD).
Jun 17, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
Dell E193Fp Blue Screen
It can be due to the effect of some kind of magnetic effect.. If your monitor has the degauss feature then degauss it ONCE and see if returns to normal. Do not use degauss feature more than once in less than half an hour. It can damage your monitor.
Nov 16, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
HP W2338h 23 in. LCD TV Logo
134 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
