Toshiba 50" the picture is blurry red and green and looks bowed inward.
    President:
  • 4,402 Answers
Convergence problem need to replace the IC's and maybe resisters.
Posted on Dec 10, 2007
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
Picture is distorted......bowes inward. Colour is
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 21, 2011 | Sony KP-57WS500 57" Rear Projection...
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
My 50" Toshiba has a color problem!!!
Ur convergence is dead.Must replaced the 2 Convergence ICS and all it resistors.By replacing these 2 convergence ICS well solved these problems colors misalign, 3D double pictures,blurry pictures.The shop will cost U $300 for parts and labors.
Jan 23, 2010 | Toshiba 50H81 50" Rear Projection...
Blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
