Question about Home
My Kohler black porcelain cast iron sink has water stains that I cannot remove. Help! I have tried so many different cleansers, even vinegar & water, nothing works that I have found. Now, it seems some of the product has made it worse.
  • 31 Answers
Try CRC
Posted on Sep 13, 2009
Removing stain from fiberglass shower base
Even caked-on iron and rust stains can be removed with a little effort. Apply your chosen cleaners to fiberglass tubs using a soft sponge, a nylon, polyester or polyethylene brush with soft bristles, or a soft cloth. Do not use abrasive cleansers, steel wool, abrasive scrubbers or scrapers on the fiberglass tub or shower surround, as these can scratch the fiberglass--in a gallon bucket: 2 tablespoons of white vinegar, 1/2 cup warm water, 1 2/3 cups of baking soda and 1/2 cup of a liquid degreasing dish detergent. Apply the solution directly to the stain and let it sit for an hour before rinsing and wiping clean.
A vinegar-and-baking soda paste applied to stained areas creates a chemical reaction that can remove the stain through the fizzing action generated by mixing backing soda with vinegar. Apply the vinegar and baking soda paste directly to the stained area and let sit for 15 to 20 minutes before rinsing and removal.
Nov 05, 2017 | Home
What do I need to clean my sink with to keep the shine?
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
Mar 08, 2011 | Jacuzzi Kitchen Cast Iron Black Finish...
My Jacuzzi kitchen sink was installed in 2004, I noticed pitting & stains within one year & reported it to the installer. He took photos & never got back to me. The sink is easily stained,...
New sink,its 2011 and its done its service to its country.Nice Kohler cast iron drop in is the way to go.Most peoples issues with sinks are abrasive cleaners ,even softscrub,it takes the finish off of all types of plumbing fixtures,cast iron- fiberglass- stainless etc.I tell people not to use anything you wouldn't use on your car finish Elkay makes some nice stainless sinks.Top of the line,let jacuzzi stick to whirlpools
Jan 26, 2011 | Jacuzzi Kitchen Iron White Finish...
Recomended cleaning for kitchen porcelain sink
Scouring powders or cleansers contain abrasives commonly used to clean and remove stubborn stains that are slow to respond to chemical action alone.
However, use of an abrasive cleaner may scratch and damage smooth finishes such as porcelain, fiberglass or enamel making it even more difficult to clean the surface in the future.
New kitchen and bathroom fixtures do not require a scouring cleanser to clean them of soap films and body oils. Dissolving soil by soaking with the correct non-abrasive cleaner (especially a foaming type that sticks to the surface) then wiping and rinsing usually does the job.
When cleaning older, abused fixtures, choose the mildest abrasive cleaner available such as a Soft Scrub -type product or baking soda, and apply just enough that, with light pressure, the embedded soils are loosened and may be rinsed away.
Aug 21, 2010 | International Thermocast Corp Thermocast...
Will Kohler Disposal Flange K-11352 work with Kohler Sink K-5924?
Kohler makes their sinks standard, and most all sinks are the same size hole, yes it will fit.
May 22, 2010 | Kohler Plumbing
Black Sink - white haze
A lot of the soaps and things that we put into our sinks can cause tiny scratches into the glaze. That's what is causing the "haze" you are describing. It's not something that can be lifted off but might be buffed out. I would recommend contacting Kohler and asking if the sink can be buffed successfully. They may be able to give you some contact numbers of people that can repair the sink if it can be. I wish I could offer some more advice but you might be heading towards a replacement instead. Good luck to you!
Apr 02, 2009 | Kohler Deerfield Smart Divide undercounter...
Cast Iron Sink with porcelain coating. The Porcelain coating crac
Kohler does have a porcelin touch up or you can get it at Home Depot or Lowe's. Not the best solution but it might help. Comes in a little bottle like White out
Kurt
Mar 15, 2009 | Kohler K-5814-4U Clarity White/Color...
How to repair porcelain/cast iron sink scratches
You can repair the sink with an epoxy based porcelin kit
Epoxy will not show brush streaks it will levelitself out do not get any kits from HD or Lowes they do not harden
Go to Sherwin Williams and ask for an epoxy paint for porcelin
As for removing the under counter sink
I would try cutting through the caulk adhesive
between the bottom of the granite and cast iron
sink with a hack saw blade
I have used a diamond blade on a grinder and
cut through but it was not a granite counter top
Be extremely areful to suport the underside of the sink with 2x4 blocks to prevent stressing the granite as you cut through
Good luck
Dec 31, 2008 | Home
Home Logo
754 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
