Question about Amana ACD2232HR Side by Side Refrigerator
Kenmore model 106.57022601 side by side. Ice maker works but the when the lever on the door is pressed nothing is comming out. My husband could fix it if we could find a manual. Does anyone have any suggestions? We do not have the cash for a repair man.
  • 93 Answers
Check the button that the lever pushes when calling for ice. Also check voltage to the auger motor. If your ice bucket is in the door then your auger motor is under it...also in the door. There is a little cover under one of the freezer door shelves that you have to take off. 3 or 4 screws hold it on. Right in there you will see the auger motor
Posted on Sep 11, 2009
2 Suggested Answers
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Water is not getting to my icemaker...I swapped the solenoids and pressed water dispenser on door and now i get water to icemaker...not sure what that is telling me is bad
You swapped the solenoid's wires. Switch the wires back.
It means the ice detect lever is up or broken on the ice maker.
See the article on ice makers at How stuff works.com
Apr 17, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Ice Dispenser not working
could be the aguar motor or door switch
Apr 07, 2009 | Amana ACD2232HR Side by Side Refrigerator
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Water won't dispense from side by side fridge
check for water at bottom of door going in, if there water line in door or tank in door freezing. only fix to replace door. ck with dealer to get fixed under warranty
Jun 11, 2008 | Refrigerators
Ice Maker Trap door may be broken
I am having the same problem. My husband took off the front panel and we discovered there is a small piece of plastic holding the ice dispenser door in place that is broken so the door doesn't seal.
I called Sears to see if the part is replaceable -- it's not. I have to buy an entire freezer door for $464 because a .10 cent piece of plastic is broken.
This seems to be a common problem. My refrigerator is only 3 years old. Perhaps we need to make a complaint to Sears/Kenmore together.
May 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Amana ACD2232HR Side by Side Refrigerator Logo
599 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
