Freezers Logo
Posted on Sep 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My intergrated Beko fridge freezer keeps beeping. I have defrosted it but it still keeps beeping! Please help this driving me wild!
Terence Fourie
Level 3:
  • Master 909 Answers
  • Posted on Sep 19, 2009
Terence Fourie
Master
Level 3:
Answers
909
Questions
0
Helped
375049
Points
2542
Tell me, what is the purpose of that beeping. There should be some indication. Lots of different alarms come up. Most common are when the evaporator fan does not transfer frost to the rest of the the fridge. So check fan for movement.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2772
Points
I had the same problem and have cured it by adding a plug in timer,
it is now off for 1 hour max twice a day,our times for off periods are 8am till 9pm 7pm till 8pm and 2 weeks of peace to date,
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 • Freezers
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 • Freezers
Thick ice build up behind freezer fan
check door rubber,if is oblate heat it with fan,if it is ragged change it.
Jun 29, 2009 • Freezers
1helpful
4answers
BEKO Frost free freezer not as cold as it should be!
hi i have same problem one of my lodgers left the door open and it froze thick with ice i defrosted it and let it dry for 3 days and was fine for a couple of days then it defrosted so i switched it of for 24 hours it worked fine for a day before it defrosted again could you email me with any help thanks [email protected] matt
Apr 12, 2009 • Freezers
2answers
1helpful
Beko cda653f
I'm not familiar with this brand of refrigerator but sounds as if you have a defrost system failure. most refrigs have a defrost timer that you can maually advance into defrost. if you can loate this on the unit then advance into defrost cycle if the heater comes on youll hear a sizzling noise from the ice melting on the heater. this means you have a bad timer. if the heater does not come on then you have a bad heater or defrost termination switch. I tried to find some service info for this mod but was unable to locate anything. good luck peyton
Jan 21, 2009 • Freezers
Fridge Freezer in Autodefrost mode
Power surge can cause problems such as you have. I am not familiar with your brand but it sounds like the defrost timing circuit is your problem. Defrosting the surface of the back wall is not the answer. The cooling coil in the freezer is behind the back wall normally and a surface defrost does not do the trick of defrosting the coil. Have an appliance service tech check it out for you.
May 30, 2008 • Freezers
Beko fridge freezer
Is it froze up? maybe it needs defrosted.
Jan 19, 2008 • Freezers
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 • Freezers
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
