Question about HP Office Equipment & Supplies
How to delete and program in speed numbers for fax
I need to delete speed numbers programmed in fax now and add my own to speed options and into phone book.
  • mich cruz
    mich cruz May 11, 2010
    do u have the hp solution center?? coz when u buy the package it comes along with a driver that includes the manual and a solution center where u can change settings including the speed dials.. is your fax brand new or second hand? and wat is the model??
    Scholar:
  • 44 Answers
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
how to delete and program in speed numbers for fax - expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Posted on Sep 11, 2009
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
Updating a Group Fax
Assuming the group name will remain the same, you can edit the Sender's name and/or phone number by doing the following:
  1. Go through the procedure to Add a Contact or number
  2. When you reach that Contact, you can edit by pressing the < key to move through the name or number
  3. Press Delete key to remove the name and re-insert the name/ same process for editing the number
The process is as follows to get to the option you need:
  1. Open all three one-touch dialing panels
  2. Press Data Registration
  3. Use up down arrows to get to Add. Registration
  4. Use up down arrows to get to Touch Spd Dial
  5. Use up down arrows to get to the desired Contact name or number
  6. Use side arrows to move cursor
  7. Use Delete key to remove and re-enter Name and/or number
  8. Once the name/number appears as you want it, Press "SET"
This should change the name/number individually and in your group.
Best of luck.
Greg
Jun 17, 2009 | Canon Office Equipment & Supplies
Re-programm speed dial keys
Sorry delete it/them and reprogram. Carl
Jun 10, 2009 | Ricoh FAX2900L Plain Paper Laser
I need to send a mass fax once a week
you need to program the numbers you want to fax in the speed dials and abbr numbers, then you can use a program key to select them all.
function-7-2-start [this is where you program your numbers]
function-7-3-start-1-start- then push your p key enter a name then hit start then select your phone numbers
Nov 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
I work for the county and I have to dial a code # first
18001234567,1234567890,1234567890
program your speed dial with 'symbols(button)' between the groups of numbers,
the 'symbols' adds a 2second delay between the dialed characters at that point.
except for the first 'symbol' the first 'symbol' pauses till the other end answers the phone and handshaking has taken place.
If the numbers are not always the same, program two speed dials, one for the 1800, one for the password.
and when sending
speeddial1 number speeddial2
Jun 26, 2008 | HP PSC 950 All-In-One InkJet Printer
Re-programing speed dial fax numbers?
Go to the Menu, select Phonebook Entry. I think it is option 3. Then select the option you want to change (Speed Dial, Phone Book, or Group). Select Modify. From there you can make changes to the phone number or name.
-M
Aug 20, 2007 | Xerox WorkCentre Pro 765 Laser Printer
528 people viewed this question
Seeker5211
Seeker5211
