Question about Teac DC-D2800 Shelf System
TEAC DC-D2800 Digital Compact Hi-Fi System
Unit was working the last time it was used. The next time it was turned on nothing worked and the right speaker had a rapid popping sound and the left speaker had a hum.
  • 3 more comments
  • Starvin Dec 10, 2007
  • Starvin Dec 11, 2007
    Speakers are correctly hooked up. If there are any fuses inside they did a great job of hiding them. There is no visual evidence of any overheating or burning on the PC board or wiring. Very little dust inside.
    Un-plugging the speakers has no affect. The display works and you can switch between the different functions. With the TUNER set on FM you can faintly hear a station through the hum on the right speaker. The turntable works but nothing can be heard when a record is played. Nothing but rapid popping noise can be heard on the left speaker no matter what function is selected. The owner's manual does not have a schematic nor does the inside of the unit's paperboard back.
    As most repair shops charge a diagnostic fee and a hourly repair fee, repair of this unit looks to be economically unfeasible.
    I think this unit is definitely tost. It will get a final trip to the recycling yard for it's final swan song. This is not the outcome I wanted but about what I expected. Thanks for the try and have a Merry Christmas and a Happy New Year.
  • Anonymous Mar 30, 2014
    Sound is not consistent
    Scholar:
  • 151 Answers
This sounds like an internal amplifier problem. Did you smell anything burn? Try turning it off completely and plugging it to a different outlet.
If all else fails, have it checked by an electronics technician...
Posted on Dec 10, 2007
  • 4,102 Answers
Check all wires to speaker are correct also if you take the unit apart you might find that their is 2 or 3 fuses inside it might be that one of these has blown.
Also check no dust has over heated anything as this is often the case when anything electrical has been off for a while.
Let me know how you get on ok
  • 1 more comment
  • paul proctor Dec 11, 2007
    Hi if their are no visible fuses inside then that wont be the problem.
    Does the unit work at all or not.
    Can you select cd or radio function or does nothing work at all.
    The problem is more than likely a blown resistor probably on the amp part of the board.
    The only way of testing these is with specialist equipment.
    It is a cheap repair and shouldnt take more than a couple of hours to do might even be something as simple as a bad solder and just need resoldering.
    But if you are unsure about how to do this or you dont have the equipment needed then it is best left to a pro also you will need a fine soldering iron.
    If you can do the repair yourself you will need the schematic diagramme for you exact unit.
    Try unplugging the speaker whilst it is off at mains then try switching it on and see if the unit is working any better.
    Could you please let me know what happens apart from the sound problem like is the display working and can you select the different setting on the unit itself.
    Hi its deffinately a problem with the amp then maybe a blown resistor it is difficult to get schematics for this make of unit the only slight chance you have will be to try using ask.com and asking need schematics for then give your make and model number and see if you can find one that way.
    The only problem is these units are only made to last the length of the warranty and you will probably find you repair this problem then youll have another one.
    So you have to thinks is it worth spending money and doing the work needed and also any other problems you might get after compared to the price of a new one.
    Hi same to you mate have a good one
I need a replacement for the remote for my TEAC Micro hi-fi MC DX220iDAB system. The remote is RC 1104 but I cant find one. Will another work instead?
Possibly. Try locating another Teac remote for another unit very similar to what you have vintage wise. Often they use identical frequencies, may not have all the same buttons, but will work.
Nov 07, 2015 | Teac Audio Players & Recorders
I need a new needle
What you need to do is look at the cartridge and find the model number of it. When you have that put it in Google and search for it. The stylus should be seen with that.
Mar 04, 2013 | Teac DC-D2800 Shelf System
I have a DC-D2831 and I am burning my LP's to CD's. I am using Roxio to do that. But when I play my CD's , I have to increase the volume a lot to hear the music . I have tried adjusting the...
Consider (and tell us) the nature of your turntable. Is it self-preamplified or otherwise running though a PHONO preamp? If not, well duhhh!
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 25, 2011 | Teac DCD2831 Mini Hi Fi System w/3 Speed...
I have a TEAC DC-D2831 Digital Compact Hi-Fi System. The Cassette Portion does not play any more. Where/who can I get to fix it? Thank you
I am in Chicago and another ex Teac manager is in New Jersey who is still doing repair work. Where do you want to send it?
Jun 08, 2011 | Teac Audio Players & Recorders
How do I get my Teac DC-D2831 CD Shelf system to come on? Nothing comes on? Not the radio, cd, cassett nor the turntable.
I was having the same problem, I read my users manual and found that there is a time button on the front of the unit itself. My husband must have pressed ithe last time he used it. Works fine now.
Nov 13, 2009 | Teac DC-D2831 CD Shelf System
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
My teac micro hi-fi system CD-X10i doesnt work
many units have a fuse inside the back cover near where the power cable comes in. be careful to replace it with the same size fuse as the problem that blew the fuse might still be there and could potentially cause a fire.
I have the same unit and i am looking for help because the cd will not run (wont spin the cd), but the door works. also the FM reception sucks.
Larry
Jun 15, 2009 | Teac CD-X10i Docking Station for Apple...
Teac DC-D2800 Shelf System Logo
345 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
