Question about ASUS Eee PC 900 Notebook
When turned on, many zeros appear, as in the whole screen.
When you turn it off, then on again, screen is black. please help.
  • gatherp May 11, 2010
    Is this a Linux or Windows eeePC900? If it is Linux, read on. It sounds like a Lilo problem, caused by the Linux boot image not being where it is meant to be. Have you moved or deleted any partitions, or plugged in and disk or flash device iince it last worked? If you have plugged any storage device in, turn off, and remove them, then turn on again. If you have altered any partitions, I would boot a Live distro from an external device (CD, DVD or flash) and see about running Lilo to repair the configuration.
    President:
  • 987 Answers
Your RAM needs to be replaced ...
bcoz this occur when the RAM is connected loosely and faulty RAM
Posted on Sep 11, 2009
Hello! My Panasonic QuintrixSR picture becomes fuzzy then thick squiggly black lines appear. The whole screen turns black yet sound still on. Can I fix this or is the TV toast? Please help, thanks.
Hi there!
Your tv is not toast yet it can be fixed. get another screen and see if their any changes .if other circuitry are fine your screen should work perfectly
May 18, 2017 | Panasonic Televison & Video
I HAVE LOST MY WINDOWS AND I KNOW ITS SETUP EXIST SOMEWHERE IN HIDDEN PARTITION ..CAN U PLEASE HELP ME THAT HOW I AGAIN RE INSTALL THAT ORIGNAL WINDOWS 7 ULTIMATE
Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear.
Dec 27, 2012 | Toshiba satellite c660
Monitor black screen
To me this sounds like whats called "bad caps" problem. The capacitors in the PSU have gone out of tolerance and the back light is switching off. If this is the case you will need a workshop repair or if you know how to solder you could replace the capacitors in the PSU for the back light.
Jan 24, 2018 | Acer AL1917W LCD Monitor
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
Wont Display Anything , Black Screen !
The screens brightness might be set to the lowest number as a joke. Try to change that.
Dec 09, 2011 | Texas Instruments TI-84 Plus Silver...
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
PC Screen Went Black, Nothing Appears
try to restart holding down F8 this puts you in safe mode then erase program and use yourestore to earlier date
Apr 05, 2009 | HP w1907 LCD Monitor
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Black Box appearing on my screen
Shut off the closed captioning and your problem will be gone.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | JVC AV-27F702 27" TV
Black Box
Hi Krautner, We have a Toshiba and experienced the same problem this morning. It is very similar to your symptoms: big black box in centre-lower part of screen. It sometimes disappears momentarily when you select a feature such a "mute" for the same amount of time the screen displays that function. Once the "mute" signal disappears, the black box comes on again. I fixed the problem by turning off the close captioning function. Somehow, it had actually got switched on. It runs fine now. I suppose you have already found a fix since you posted back in May....but hopefully this helps you or someone else putting in a similar search for this fix. Cheers Geo
May 09, 2007 | Toshiba 46HM95 46" HDTV
ASUS Eee PC 900 Notebook Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
