Question about Dishwashers
Hi, i have inherited a diplomate dishwasher. It is now tripping out the electrics. I have tried to find model number but all that is visable is the serial and service numbers.
Your heater element may have an electrical leak down to earth the circuit breaker will detect this and trip. The only solution is a new element
Posted on Nov 08, 2009
  • 33 Answers
Make shure the wires are hooked up right (black to black & white to white)
Posted on Sep 13, 2009
Hi, my zanussi izzi dishwasher has started acting up, it will start a cycle but after a couple of minutes it trips out the main RCD in the fuse board, now i have isolated it to the dishwasher itself and...
If it trips after a few minutes of coming on , it is probably the heater which is faulty , disonnet it and try , if it doesn't trip you need a new heatee
May 02, 2017 | Zanussi 24 in. IZZI ALU Built-In...
When switched on the machine trips the power. Changed fuse in plug and tried different socket but still same problem? took bot of machine no visable burn or soot marks? any ideas
Is it tripping the breaker in the breaker box? If so you have a short to ground. Could be A bad spot on the dishwasher cord. Turn power off and pull dishwasher out and check the power cord all the way back to the dishwasher terminals
Dec 31, 2009 | Dishwashers
Where is the model number on a kenmore ultrawash i can't tell u the model number if i cant find it
For the model number, Usualy there is a bottom "Kick plate" held on by two screws on the very BOTTOM of the dishwasher. If there is no visable plate inside or around the door frame check under there.
Nov 11, 2009 | Dishwashers
AEG Favorit 35085 vi trips electric every time
Simply things to check, you want to make sure your electrical connections are all tight, at the breaker (If your comfortable) and at the connection under the dishwasher. It's possible that the breaker may just simply be going bad. If you have a Amp meter you could run the Dishwasher and see how many amps the washer is pulling, and com pair the amount to the Name plate data where the model number is at, its usually listed in the same place.
Good Luck!
Nov 04, 2009 | Measuring Tools & Sensors
Dishwasher fills with water but when it should start washing it sounds like the pump trys to start and trips out, this happens over and over while still filling. any ideas?
Hiya,
without the make and model number its hard to tell exactly what the fault is,
Generally this is caused by a siezed motor, could be something got into the impellar or worn out.
When you say trips out, do you mean electrics trip?
If so, you have probably had a leak in the base of the appliance and shorted the motor.
Hope this helps.
Regards
Sussex engineer...
Please rate my help.
Oct 22, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Inherited diplomat dishwasher with my house
Today's dishwashers use less water and less electricity so the manufacturers have had to increase wash times to get good results. One hour is about normal for the "eco" cycle since it's always "sensing" the water turbidity (soil in the wash water) and water temperature, and making adjustments as necessary.
Your shortest wash cycle would be "delicate" but it might not give you the best results.
Mar 05, 2009 | Dishwashers
Neff dishwasher trips the electricity
It could be faulty wireing in the dishwasher connection or you could have a leak in the washer causing the wires to get wet. I would have an electrician have a look at it.
Dec 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
136 people viewed this question
Top Dishwashers Experts
Owen Barnes
