Need code for remote gtx under cabinet tv - Televison & Video
    Sergeant:
  • 270 Answers
Dawnload it from the manufacture website.
Posted on Sep 11, 2009
I need setup code for my zvox sound bar for a Comcast remote?
I am the same boat. Just bought a bigger tv and my zvox doesNOT work now
Jan 26, 2015 | ZVOX 4002201 Audio Z-Base 220 Low-Profile...
BLUESKY
Hi, each TV has its own specific set of codes it uses. But regarding universal remotes and programming them they are all different. universal remote manufactured by "one for all" might have the working set of codes for your TV under code 1234, and universal remote "RCA" might have the working code for your TV under 987. so the code depends on the universal remote you are using.
So we need to know the brand and model number of your universal remote you are programming to find you the correct code. And even if we do find the correct remote and manual for your universal, there is a big possibility that the universal remote will still not work.
Nov 30, 2012 | Televison & Video
Nvidia GTX 570 to Protron 32 LCD. I'm getting improper mode when I go to VGA (source) and I have the Nvidia set for 1366 x 768. Have it set to 85Hz. I see pc comes up under menu. But not sure...
The TV doesn't support either the resolution or the frequency you are running.
When running a PC to TV set, you should be running at 60Hz and use a standard frequency like 1024 X 78 or 1280 X 1024
May 27, 2011 | Protron PLTV-32 Television
Are your under cabinet mounted TV's Dish network compatable? If so what is the code for configuring the Dish remtoe to access the TV. It is not necessary that the remote control the DVD area.
We would be happy to help you with getting your DISH Networkremote to control your Venturer TV. We currently do not have any codes for the brand Venturer so we would need to perform a power scan. A power scan will scan your DISH remote for any codes that will work with your TV. Here are the steps for a power scan:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 11, 2010 | Venturer PLV36220CS5W-DC LCD TV
My remote is lost, i have a universal, but i need codes!
you should have the manual for the universal remote. go to the universal remote website for a listing of codes and just look under gpx. all gpx codes will work with just gpx.
Feb 19, 2010 | GPX KL858S 8.1 in. Under Cabinet TV
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Need code for remote. New remote needs replacing.
Cable and Satellite content providers control the remote codes,
and we apologize for any confusion during the remote programming.
Please try the following codes 10019, 0178, 10178, 0030, 10030,
0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
TV (Verizon), try the code 3264. These codes may not work on some
universal remotes. If there is another code listed for Element
Electronics in your universal remote control guide, please try that
code. Refer to the Remote Control Guide under your TV’s model
number for more information.
May 09, 2009 | Element ELC-HS321 32 in. LCD TV
Polaroid TV Code
About the only thing you can do is do a code search. If it doesn't show up then, the remote does not have it (as with most tv/dvd or tv/vcr combos).
Turn the TV on manually. Then, push the switch at the top to the far right (to the TV position). Simultaneously press and hold the MUTE and SELECT buttons until the TV light at the top flashes. Release the buttons, then press and release 9, 9, 1. The TV button should flash again.
Press and release the 1 button again, then press and release the TV POWER button. Press and release the Channel UP button about once a second until the TV turns itself off. Press and release the select button, and you should be good to go.
If after a while, the TV button starts flashing rapidly, then there are no more codes to search, and the remote does not have the code, and you are stuck using 2 remotes..
Hope this helps...
Jan 07, 2009 | Polaroid 4226TLMB 42 in. LCD TV
I am trying to program a new remote and i need my remote code to program the tv can you find the code for magnavox msd513f
Not sure your MSD513F is not listed, and dont know your chassis # so here is what I can offer with what you gave me from the manuals
FOR THE
51MP392H/17
PHILIPS phone # 1-800-432-8542
Universal remote control - RC2018/1
Universal RC managing TV and peripherals
from the parts manual
Cabinet & Accessory Parts
REMOTE Transmitter, RC2061/01 . . . . . . . 3128 147 14611
Sep 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
