Question about Lacava Design DROP IN PORCELAIN SINK - 5055/42 - White
In the bottom of the sink it reminds you that something was poured in sink and ran down drain and let that area gray/discolored and down close to metal so anything grabs on it and it stays discolored
  • 30 Answers
Depending on how old your sink is or how hard your water is, you may have an issue with mineral build-up on the bottom of the sink. If it's calcium, it would be white, so you wouldn't be able to see it. This sink is porcelain, so it isn't porous and should feel completely slick to the touch, especially when wet.
If it isn't, try cleaning it with a melamine sponge. There are various brands. They are all white rectangular squares and come with names like Magic Eraser (it's all the same stuff). This is a very fine but hard abrasive that should be able to clean off any film. If you continue to have issues, you can also use a cleaning product formulated to remove soap scum (like Scrubbing Bubbles).
Posted on Sep 18, 2009
How do I unblock a kitchen sink that still won't drain after I poured a huge bottle of Draino Max and 2 medium size bottles of Ace Hardware drain cleaner over a period of 3 days and as soon as I poure
The fact that you ran a 15ft snake into the drain begs the question How long is the run from your sink to the main drain? Next is this run vertical , horizontal? does it go round any bends on its way ? and how does it terminate in the main drain?
If you are not on the ground floor most sink drains terminate in a soil stack riser and these connections are prone to "furring up" as they are slightly smaller in diameter at the joint point.
If however you can follow the sink waste pipe to an open gird or capped drain check the route for damage as a loose coupling can easily cause a blockage if it is weeping.
Again without more info' can only guess but if you are in a shared block check with the neighbours to see if they are having similar problems as it may be that the central riser is blocked.
HTH.
Jan 01, 2015 | Ace Hardware Electrical Supplies
Tip
How to Sanitize Your Dishwasher
Step 1 -
Get rid of any odor that may be coming from the plumbing pips your dishwasher shares with the sink. Pour a half of cup of baking soda down each sink drain. Pour cups of vinegar down each drain until all of the baking soda is washed away. After five minutes, run very, very hot water down each of the drains.
Step 2 -
Clean out your garbage disposal. Slice a lemon/lime and put the slices down your disposal drain. Run your disposal with cold water running.
Step 3 -
Pour two cups of vinegar into the dishwasher and let it sit for an hour and then let the dishwasher run through a cycle with the hottest water possible. Repeat the process is that does not clean up all of the build and film. You can use baking soda and bleach instead of vinegar - just sprinkle the baking soda in the bottom of the dishwasher tub, and pour bleach inside the tub as well.
Step 4 - Between washes, pour 1/4 cup of lemon juice into the dishwasher cup and run a short, but complete wash cycle. This will not only deodorize the dishwasher but will also help get rid of any metal build-up.
on Oct 19, 2011 | Frigidaire Dishwashers
How do we remove the horrible smell in our Bosch dishwasher?
First check out your model to see if it has a built in garbage disposal, if so, make sure it is not mucked up.
Run hot water down your sink drain while running the sinks garbage disposal. Pour baking soda down your sink garbage disposal followed by white vinegar. Let it sit and foam. Run hot water down sink disposer while running. When finished:
Run empty dishwasher with no soap, let dishwasher fill with hot water to wash and then pour 1 cup of white vinegar into the bottom and resume wash. Make sure you take it through the dry cycle. When finished, open dishwasher and let it air for a couple of hours, longer if you live in humid area. Hope these steps do the trick.
Aug 03, 2014 | Bosch Dishwashers
Smeg di612ca dishwasher won't drain water
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck. Did you have to dishes without a dishwasher once? If this doesn't work think of it as a pleasant reminder of the good ole days, whilst scrubbing them by hand at the sink. Use an apron to keep from getting wet.
Dec 21, 2013 | Dishwashers
Kenmore ultra wash II dishwasher has standing water in bottom of washer Where can i pour drano
no drano but a lot of tomes the drain hose under the sink where it drain into the garbage disposal needs to be looped up when you use the sink where the disposal is it drains back down into your dishwasher
Dec 15, 2013 | Dishwashers
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
My sink smells like septic
Assuming the smell is from food particals trapped in sink, and not from bad plumbing allowing gases back up the drain, I would do following.
Boil a large pot of water. Pour a cup full of ordinary bleach in sink, CAREFULLY pour hot water slowly into sink. AVOID breathing bleach fumes which will clear very quickly as it washed away.
For dish washer, use a cup full of bleach with about a quart of cool water in the bottom of dishwasher, close it and run it empty. Once it goes past the first stage, to where it begins to refill, you can interrupt it if you wish. Depending on model, may be better to let it complete.
Jan 30, 2011 | Dishwashers
Water drippinp from the bottom of badger 5
Check all of your seals. Wipe your hand all the way around your disposal to check for moisture running down. Pay close attention to the areas where there are seals, like the top where the main gasket is located and the side where your drain connects there are rubber gaskets that can begin to leak. Also check where the dishwasher drain connects if applicable. If all gasketed areas are ruled out than unit itself may be leaking and need to be replaced. I hope this helps.
May 26, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Lacava Design DROP IN PORCELAIN SINK - 5055/42 - White Logo
110 people viewed this question
Top Lacava Design Home Experts
Donni Steen
Tom Chichester
Are you a Lacava Design Home Expert? Answer questions, earn points and help others
