Question about Frost Freezer WCWO F15WA FREE - POCKET HANDLE - L
Need help, fast
My daughter was trying to defrost a freezer by chiseling away at the ice when she seemed to have hit something, it's now making a hissing noise, will this cause some kind of hazard?
  • ajansmom Dec 14, 2007
    Thank you, we have since gotten rid of the fridge, it was a small, cheap one so we figured it wouldn't be worth paying to have it repaired, Yes, we know that but we needed it done right away, dumb, we know!! Lesson learned!
  • Anonymous Mar 23, 2014
    My woods freezer, almost every time it starts, makes some kind of banging noise for about a minute or two, then goes away.
    It seems the noise comes from the back, around the middle. What can that be?
    Thank you, Gus
  • 40 Answers
Sounds like she put a hole in the evaporator.BAD NEWS!!! If it is accessable it may be repaired and the unit recharged. The proper way to defrost a freezer is to empty it and pull the plug with the doors opens.Let it melt on it's own.
Posted on Dec 14, 2007
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Sep 16, 2013 | Sub-Zero Freezers
Only 6 months, have to defrost.
However this will take long so you use a straight screwdriver or something like a chisel to remove as much scale as possible before leave it in solutions.
The ice build up is related from the time keep the door open and the humidity that is in the air. So the time is variable. Sometimes if the door is not sealed closed the ice is build up very fast.
Nov 01, 2010 | GE 14.8 cu. ft. General Electric Chest...
Door was left open a little bit now it is making a sound . like a fan is hitting something . can you help
Yeah the fan is hitting ice that built up...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | Freezers
I have a true tuc48-f freezer..Problem: Frost build up to the point that the doors freeze shut and I have to scrape the ice off. Also at time it make a rackety noise like the fan hit solid ice.
It seems you have diagnosed your own problem.
Check the defrost circuit. It appears your defrost cycle is not working.
Also,check the door seals closely.
A loose or broken door seal can contribute to these symptoms as well
Sep 17, 2010 | True TUC48FADA Freezer
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Ice forming very fast on top shelf only
You said you checked the seal but one thing you can try to be double sure the seal is tight put a thin layer of vaseline along the entire seal it will fill in any gaps and you can be sure it is sealing completely.
Jan 05, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Fan making loud noise like its hitting against something
take and defrost the unit and make sure that the drain line is clear. this should solve it. Thanks for using FixYa.
Dec 25, 2008 | Freezers
Kenmore upright freezer
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
137 people viewed this question
Top Frost Freezers Experts
ray gallant
Ken Wieczorek
Ken Wieczorek
Bill Boyd
Are you a Frost Freezer Expert? Answer questions, earn points and help others
