Question about Maytag Washing Machines
Old Maytag Neptune washer will not ring? - Maytag Washing Machines
  • 11 more comments
  • mavessel Sep 11, 2009
    Maytag Neptune front load washer model MAH3000HWW
    WILL will not go into spin cycle, it does however wash and rinse, need more than a general trouble shooting.
    showing my age, LOL. yes it will not complete spin cycle. it runs very slow and then shut off.Of course you know this is a computerized panel right?
    I have not gotten any information, the first was a generalization, the second was a question????did I mean spin cycle of course I meant spin cycle, I initially said ring, my error.
  • mavessel Sep 12, 2009
    Hi, at least you addressed my problem. I made an error on model # it's MAH3000AWW, Now where do I get the possible needed board, and would a layman be able to replace it?
    How does one reset the circuit breaker? need instruction on how and what to do.
    So what you're saying is I've got to get a repairman, which I was attempting to by pass??? Would it be wise for me to purchase the part before the repairman come and analyze the washer?
    I was hoping I may be able to correct this issue with some detailed instructions perhaps a detailed diagram????? My whole thing for getting fixya was to fix it myself
    yes the motor is running but rather sluggish, only for a few seconds then it shuts off. the other cycles are responding.
    I just pasted the info you gave me and went around in circles. I do need real help here, please
    still requesting help
    okay, let's go that route, maybe I can get some info on how to trouble shoot and determine what my problem really is. what do you think?
    because it's computerized, I'm wondering if it is the door lock, troubleshooting is really the thing to do I believe. I had a similar problem about 6 years and something was done in the panel on top???
    hI failed to give the manual site to me
  • 313 Answers
Well lets see if we can get you started of the right foot her. You would like to do this yourself. It is pointing to the curcuit board. But lets start smart, if you want to do it yourself you are going to need the the service manual. the link below will get you that. they have discontinued the manual so you can't buy or download it. but for the minute you can still print it from this site.. that would me my forst suggestion. Let me know if that sounds good and you want to continue..
Posted on Sep 12, 2009
  • 2 more comments
  • Randy Trent
    Randy Trent Sep 12, 2009
    Your going to have to look and read the section you want. it will not print either.
  • Randy Trent
    read section 2-1 and 3-1 and let me know if you still want to do it yourself.. If you do and you are comfortable then we will go from there.
  • Randy Trent
    It looks like it might not be that bad if whe=at I am reading is right. That the only issue really is that it shuts off during the "Spin Cycle" That makes it a door problem. you may just need to replace the door lock machanism. I will give you a link on where to buy that her shortly..
  • Randy Trent
    Here is the link to where you can get the part.
    http://www.repairclinic.com/Appliance-Pa...
    The parts you need are
    1. Spring, latch
      Item #
      454911
      Price
      $5.60
    2. Support, lock hoop
      Item #
      454915
      Price
      $3.95
    Without actually being able to physicaly see the washing machine. the service manual suggest this is the solution. The sping is worn and needs replaced.
    President:
  • 497 Answers
Are you referring to an end of cycle ring? not quite sure what you are talking about.
  • Greg Mills Sep 12, 2009
    www.the-manuals.com is a good website to check them out, sorry for my earlier post, i didnt read all the comments.
    Seems like its a ECU failure.
  • 11,896 Answers
This could be the switch not activating that cycle. Can you hear the motor turning? Does it do anything in rinse mode? If the pump was faulty, it would also cause this to happen.
Please copy and past this link in your address for more and feel free to ask any quesions:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
  • 6,784 Answers
HI. This unit utilizes a motor control board. This module is responsible for initiating the proper motor speed during each selected cycle. Any damage that may occur within the chip set, will cause the actual issues you are experiencing at this time.
It is possible to reset this chip set by shutting down the appropriate circuit breaker, or unplugging the unit for 5 minutes. If the reset dose not produce positive results, i recommend the replacement of the affected board, which is the Motor Control Board.
  • Michael Masters
    Michael Masters Sep 12, 2009
    Ok. the part number for this affected part will be 22004046, and you can purchase it at the link i will provide below. I recommend to contact a local service professional for this replacement procedure, due to the degree of difficulty with this issue. The entire unit will need to be disassembled, in order to expose this damaged motor control board. It is located in close proximity of the motor itself. Click on the link below to order the Motor Control Board.
    CLICK HERE
  • Michael Masters
    Ok. the easiest way to initiate a hard reset, will be to unplug the unit from the wall, if possible. If this is not possible, the alternative will be to shut down the appropriate circuit breaker. This breaker will be located inside your home or, garage area. The breaker switches will be inside a wall mounted box. There should be a door that will have a latch to relieve, Once the door is opened, you will see a guide on the inside part of the breaker box door. This guide will have all the breaker switches listed in numerical order. The numbers should coincide with each room and utility area in the home. each switch will represent a specific power outlet and wall light switch as well. simple shut off the appropriate switch that controls the washer units power outlet for five minutes.
    President:
  • 1,714 Answers
I'm not sure I understand 'will not ring' ??? Do you mean 'spin cycle'?
Posted on Sep 11, 2009
  • Maytag Master
  • 19,396 Answers
there are many possible faults that can affect a washer.
Click Here to open a general troubleshooting page from Repairclinic, they also sell parts.
To help you better, please give us details on your washer model, and more details on the problem.
Many thanks.
4 Suggested Answers
  • 96 Answers
SOURCE: maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Posted on Jun 08, 2008
localwonder
  • 6784 Answers
SOURCE: my maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Posted on Jun 17, 2009
Illeagle
  • 525 Answers
SOURCE: Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Posted on Jul 18, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have that moldy/mildew smell in my Neptune TL. I called about three years ago and they told me to run cascade through it. Now it is back and worse than ever and nothing seemed to help. My husband took...
yes there was a huge class action against maytag they are building rubbish we have machines here that are 4 months old and maytag wont cover there warrentys .. and they were the best washers you could ever buy till they were bought out by china. but they settled in 2004 but there are still many going on here is a link to get you strated.
good luck with it next time buy lg. how do we know there good? we have fixed 2487 washers this yr alone and only 4 of them were lg they are great machines.
http://www.consumeraffairs.com/news04/2005/maytag_lawsuit.html
Aug 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Rubber ring around the inside is very moldy and stinks it is the neptune washing machine Maytag neptune washer
For a thorough breakdown on how to resolve this problem - please view this FixYa Tip.
Hope this helps - if so please remember to leave a vote for the solution.
Thanks.
Nov 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
Sound like water still in washer
its water in the tub ring only thats to balance the load while in use..no water in bottom of tub,,you will here the sound of water in the ring when door is open and tub ismove,,but thats all..you will never see water,,if you see water there a problem..onthejob
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
When the door lock fails, there is a part on the electronic control board that fails (resistor burns up). Both will have to be replaced.
Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
244 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
