If you are sure the battery is not low/defective and the laser turns on the chances are the LED display is defective, since they don't sell or publish service information for the user to repair his own unit then you will have to send it in either for an exchange unit or have this one repaired, whaich will require a longer turn around time, contact Busnell about where to get the unit serviced/repaired.
Comments:
Sep 11, 2009
- you can't buy the parts to replace the display so looks like you will need to send it in for repair
Sorry for the lack of help you have been receiving.
This info is from another FixYa expert. Hope it helps:
If all the LCD display segments will not
clear or E31 is displayed.....It needs programming and/or a new CPU board. Usually, leaving
batteries to die (in the off season) or using heavy duty batteries can cause
this.
Is it possible to get a parts break-down for my Bushnell Pin Seeker 1500 20-5103? When turning the...
(More)
Is it possible to get a parts break-down for my Bushnell Pin Seeker 1500 20-5103? When turning the eyepiece, it no longer "clicks" or stays in position. Looks or feels like detents are missing.
How do you clean sand out of your pin seeker? It was dropped along the cart path in an area of sand...
(More)
How do you clean sand out of your pin seeker? It was dropped along the cart path in an area of sand and sand got in the view finder. When you twist the end to open the lens, it sound really gritty. Is there any way to take it apart to clean it?
The rangefinder appears to take a reading, the cross hairs show on the LCD display, but no yardage...
(More)
The rangefinder appears to take a reading, the cross hairs show on the LCD display, but no yardage is shown.
My Pinseeker 1500 seems to have lost the ability to read anything outside of about 120 yds, even...
(More)
My Pinseeker 1500 seems to have lost the ability to read anything outside of about 120 yds, even with a fresh battery. Inside 120 no problem, outside it just acts as though I have not sighted in on anything. Any suggestions?
