Question about Lanzar Car Audio & Video
Airspace requirements for lanzar opti 1533d - Lanzar Car Audio & Video
3 Suggested Answers
  • 84 Answers
SOURCE: how 2 bridge tha opti drive 1222d 12inch subs 2 the opti 600x2hc
You can check Both Crutchfield's learning center on subwoofer wiring diagrams and www.the12volt.com with their wiring diagrams. The crutchfield setup will be more informative for this type of problem. Just go one of the + to one of the - on each sub then wire the other plus's together between the subs as well as the minuses like between the subs and use the open plus and minus that u didn't just bridge. Then there should be just 2 wires a plus and a minus to the amp. Then follow the amp bridge wiring which should be found right above the speaker terminals it will be left plus to right minus or the other way around
Posted on Jun 14, 2009
  • 256 Answers
SOURCE: i have an old lanzar
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Posted on Mar 18, 2011
I just bought a old school lanzar opti 50c amp but i need to know what is the postive and negtive for the speaker output and what one is for bridgeing?and what is the spec? what is the lowest ohm i can go
the 50 C was used as a cheater amp back in the 90. You will be shocked by what this thing is capable of doing you can run an entire system subs mids and highs off of this 50 C. About 1300 watts
Jun 19, 2011 | Lanzar OPTI 50c Car Audio Amplifier
I have an old lanzar 10 inch subwoofer that is open airs series and need to know the required airspace for best performance
Feb 11, 2011 | Lanzar MAX12D Car Subwoofer
My Lanzar Optidrive plus has a green light and a red light. I assume this is a sign of safe mode. normally it is just green. How can i get it back to normal and in working order. I already tested other...
your output of the amplifier have been distorted. I suggest you take this to a reputable service technician that has experience with lanzar OptiDrive old school Rockford Fosgate or Orion. These technicians are hard to come by nowadays but they definitely are worth the money that they charge. I happen to be one of those such technicians.
Nov 15, 2010 | Lanzar OPTI 50c Car Audio Amplifier
Need to know airspace required for this sub
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
Jun 19, 2010 | Lanzar MAX12D Car Subwoofer
I have a Lanzar Vibe 235 amp. the green power light is not coming on, but the red "protect" light is. how do i solve this problem??
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to purchase an old school Lanzar Opti Drive. Any of them. The 50 will kill some 12" subs .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe-235-amp-green-power-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Mar 11, 2010 | Lanzar Vibe 235 Car Audio Amplifier
Blown car amp repair (Lanzar Opti 150 stereo bridgeable car amp)
its better to change them all. than to change 1 or 2 mosfets, bcuz simetimes it affects the other mosfets. and please check your speaker or maybe there is an resistor, capacitors, or a relay malfunctioning in that area.
Jan 18, 2008 | Car Audio & Video
Please save my 50c
sounds like inputs are blown or channell blown!!! are you running high output preamp???
either way cheap fix,i had to repair a few of the opti inputs last summer for a customer if you need more info drop me a line 574-220-0162 Randall
Nov 18, 2007 | Lanzar OPTI 50c Car Audio Amplifier
Car Audio & Video Logo
158 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
