Question about HP Hewlett Packard LaserJet 1600 Printer
Laser jet 1600 printer high pitched squeal
Laser jet 1600 printer has very high pitched, loud squeal only when paper is running thru printer. Sounds like it is coming from place where paper exits. Help pls, its driving us crazy.
Printer is ~2.5 years old. No other problems.
  • wnha Sep 11, 2009
    Didn't see picture you mentioned
  • 44 Answers
It proberly has dust in the printer near the spool (the picture below)
Laser jet 1600 printer high pitched squeal - ink-jet_printer_inside-cartridges.jpg
Posted on Sep 11, 2009
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Hp p4015x that is making a loud high pitch squeal
toner cartridge or fuser or laser/scanner assy
Feb 24, 2015 | HP LaserJet P4015N Printer
My Hp 1200 laser printer makes a high pitched squealing noise and I have to pull the plug out to stop it.
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 13, 2014 | HP LaserJet 1200 Printer
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Hp laser jet all leds on and not working
The surge protector or UPS may not be allowing sufficient voltage through to the printer. HP printers do not have built in speakers of any kind. Because of this, they are not capable of making any beeping or squealing sounds. If any noises such as these are heard then the printer is probably connected to an Uninterruptible Power Supply (UPS) or a backup battery. To verify that the UPS is the source of the noise, plug the printer directly into a wall outlet bypassing the UPS.
The following are common symptoms:
  • High pitched squealing, beeping sounds, or alarms (UPS)
    NOTE: Noise over the phone line can also cause high-pitched squeals and beeping sounds.
  • Inexplicable or false error messages
  • Printer will not "wake up" from sleep mode
  • Printer appears to be DOA
  • Incorrect printout
  • Slower than normal printing
  • The printer control panel display is blank or shows garbled characters
  • Accessories, such as attached copier/scanners, do not function properly
  • Monitor loses power or shuts off
  • Computer reboots when job is printing
  • Job only prints half way, causing a paper jam
If it is necessary for the product to be connected to the above-mentioned devices, consider the following items:
  • There are many UPS configurations and load conditions that can affect proper printer operation. Depending on these configurations or load conditions, printer functionality cannot be predicted.
  • No damage to current HP LaserJet products will occur, but, depending on their particular UPS configuration, the printer may or may not operate properly.
  • Printing while on a UPS battery backup is not recommended because of the large power requirements of HP LaserJet products.
  • If the HP LaserJet printer is not operating properly and power line conditions are suspected, try a different circuit (a different wall plug located away from the current one), or try removing it from the UPS.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | HP LaserJet P2015n Printer
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Brother Intellifax 5750e Squealing
sounds like your laser unit is getting ready to "bite the dust".
razors
Jun 24, 2009 | Brother IntelliFAX 5750e Laser Fax
2000 Beetle Loud Whirring at start up
its your secondary air pump. it turns on in the cold morning to inject more air into your exhaust, something about emission. its normal to be high pitched. once on my car it was way loud, i looked and the hose had disconnected. either way its normal if its not super loud. but if its everyone is looking at me loud then check for loose hoses!
Apr 03, 2009 | 2000 Volkswagen Beetle
High pitch squeal, not picking up paper
it's not the gear..you are having a seized mechanism, most likely from something stuck in there.
Mar 13, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
HP Hewlett Packard LaserJet 1600 Printer Logo
343 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
