Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Replacing washing machine brushes in motor how do i take out old ones
    Brigadier General:
  • 3,513 Answers
Hi
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Thanks for contacting fixya.com
Posted on Sep 11, 2009
SOURCE: Frigidaire Gallery FWT449GFS1 washing machine
http://www.repairclinic.com/referral.asp?R=154&N=1094128
The internal brush can be used to replace brush in similar holder on certain Electrolux, Frigidaire, and Kenmore washers (at least motor # 131276200).
Posted on Jan 02, 2008
  • 8 Answers
SOURCE: remove carbon brushes from bosch washing machine
bad news im affraid mackem , depending on what motor your bosch has there is no way to change the carbons without removing the motor .
Posted on Feb 25, 2008
SOURCE: Bosch Maxx 6 WFL 2061 Front Loader W/M
brushes usually available on ebay,
if the drum rotates but does not spin, this could likely be brushes or component problem (i.e triac or relay) on control PCB. - the latter was the problem i had and this was easily spotted as a blackened track on the Relay on the pcb.
Brushes should be ~£5. - check the existing brushes first before buying them.
fitting is easy, BUT a word of warning..which you probably know anyway..
before meddling though in the machine, locate the large capacitor and with electical screwdriver and discharge all the terminals to earth first! - YOU MUST DO THIS TO AVOID ELECTRIC SHOCK!! - even if the machine is unplugged.
remove motor & undo the back plate to release old brushes.
clean of motor of any excess carbon dust, - this can eventually cause arching if not cleaned away.
reassemble and fit all plugs back.
THEN TAKE 5 MINUTES TO CHECK WHAT YOU HAVE DONE BEFORE SWITCHING ON. -
Do not rush anything - take your time.
Posted on Apr 26, 2008
SOURCE: beko wma 510 w washing
new pump washing machine will not spin or empty. what could be the problem
Posted on May 20, 2009
Call a few hardware store....I think I found my brushes at True Value. Then take the brushes/case & spring to a lawn mower etc. repair shop...they charge you a few bucks to get the right angle and length with the spring and case. Hope it helps!
Posted on Aug 29, 2009
Just done a cold wash (C on the dial)and the machine isn't spinning after the rinse cycle.... It's 22 yrs old, washed my uniform and two messy kids clothes for years in four separate houses, and tru
Sounds like the brushes on the motor have worn right down.three choices replace the brushes (eBay) replace the motor and brushes £30 ( eBay) source a replacement machine.EBay local newspaper but search for 25 to 50 mile radius.sometimes sellers will deliver a working machine for little extra and it works out cheaper than buying a new one.
Jan 03, 2015 | Zanussi Washing Machines
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
Oct 04, 2014 | Bosch Washing Machines
Fault F21 Dead Washing Machine?
If the display is now dead, the brushes will not make it work. Replace or repair the control board.
Mar 03, 2014 | Water Heaters
Can anyone tell me where I can get carbon brushes for a Bosch WFMC1001UC/09 washing machine. Bosch does not sell or list the part. They say you have to replace the motor as a unit. The number on the old...
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me from repairclinic.com. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Dec 28, 2011 | Washing Machines
I have a front loader washing machine that is about 5yrs old the ellectric motor has worn its brushes out and i would like to get some new ones is this able to be done?
Hi just read your posting.Now I need to know what country you are in and then I can hopefully let you know where to buy a new set of brushes for this machine. Please reply and I can also guide you in the replacement of the brushes as well.Looking forward to your reply.
Oct 14, 2010 | Westinghouse Washing Machines
Indesit omega 1100 won't spin or rotate with clothes in
Sounds like the brushes in the motor need replacing, remove the motor, and check brushes, if they are less than 2-3 millimeters long, then they need replacing, not too expensive.
Please rate my solution.
Thanks.
Oct 28, 2009 | Washing Machines
HO DO YOU FIT BRUSHES TO A WFR2866GB WASHING MASHINE
remove motor,
remove motor brush cover screws from the motor
shake out old brushes
insert new brushes, spring side out
install brush cover screws
install motor
Sep 27, 2008 | Bosch Washing Machines
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
249 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
