Question about Hitachi 61SDX01B 61" Rear Projection Television
Red in picture creates a ghost picture
The red in the picture will sometimes jump and it will create a ghost picture of itself in red and then it will dissipear after a while but comes and goes throughout the day
  • lockman Dec 11, 2007
    where might that be located and can i fix it myself i am pretty handy and oodles of tools lead the way. -please
  • lockman Dec 14, 2007
    now thw upper part of the picture is bowing in a downward shpae with a green line on outer rim of the bow ...hmm thank you all for your help so far hope i can fix this thing any ideas
    President:
  • 4,402 Answers
Sounds like a loose connection in the convergance amp ic's
Posted on Dec 10, 2007
  • Cary Farah
    Cary Farah Dec 11, 2007
    i will send you a link to a tv that has the same problem
    http://home.earthlink.net/~oleg.filippov...
    or
    http://cmpalmer.blogspot.com/2006/11/fix...
  • Cary Farah
    Cary Farah Dec 14, 2007
    you can also send it to pts
    www.ptscorp.com/
How to make ghost image of windos 7.
Are you reffering to Norton Ghost? If so newer versions require that you install the software on the pc itself, from there you can select to do a full disk back up which will create a system image.
If you have an older version you can actually boot from the CD-ROM on system boot and create your image from there.
Mar 13, 2011 | Computers & Internet
Is it possible to create one generic win 7 ghost image and use it on any pc or laptop. I've tried this in the past with xp and it was an epic failure; sometimes it worked after ghosting, sometimes it...
A ghost image can be used on only one computer the same image cannot be replicated on other machines. Create a different image for the other computers and then burn the image file to the DVD drive for future use.
Dec 19, 2010 | Computers & Internet
Color red is warping or ghosting
You need to have the convergence chips replaced.
It liiks like 3D?
Thanks for using FIXYA
Oct 26, 2009 | Televison & Video
Yellow, blue and green ghosting of picture. Convergence mode will not allow realignment of the red and blue lines
Hi,it sounds like a light engine problem.Lcd Technology uses 3 chips blue,green and red that create the image ,when they start to fail color discoloration will occur.If it's an Dlp pay attention to sounds of buzzing,whirling and high pitch sounds because it could be your colro wheel.
Oct 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Self installing image
Try Acronis True Image. Similar to Ghost but works better. You can create an image of your system on a separate partition. When booting your system, you can recover from this image by pressing F11. Sort of like the hidden partition some companies put on a hard drive to return it to factory state. Only you create the partition yourself.
Aug 08, 2009 | Computers & Internet
Samsung HCN4226W "image pinching"
The convergence IC has gone out and is located on the Main bd or the Power supply bd depending on the specific model and must be replaced and a Full convergence alignment must be performed to return your tv to a watchable condition. Only a Samsung trained tech can do this.
Jul 16, 2009 | Samsung HCN4226W 42" Rear Projection...
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Ghost dell 2500
Just run Ghost in windows and follow the wizard to create a bootable floppy for your hardware
Feb 20, 2008 | Dell PowerEdge 2500 Server
Red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
May 07, 2007 | Mitsubishi WT-42315 42" TV
Hitachi 61SDX01B 61" Rear Projection Television Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
