When turned on it flashes "E, 70" and will not print.
There is a clicking / knocking noise when the printer is asked to print, and says scanner error.
Not sure which equipment you mean here - the header mentions Canon camera, but the query appears to relate to a printer. If it is the printer that is causing problems, it could be that the paper needs reloading - on my Eps*n, when using glossy photo paper, the lower corners usually require gentle straightening before the paper will feed.
Jun 12, 2016 | Vivitar Cannon Eos Rebel 70-300mm With...
I have a HP Designjet 70 printer and lately it will only print one job at a time. I have to turn it off and then turn it on for each poster I print.
when its feeding paper from the cassette - does it retry 2 or three times before the paper is pushed into place?
This is the most common call on the small plotters, feed rollers either dirty or worn down (smooth no treads), also bloew where the rfeed roller silts , attached to the tray is a small rubbery pad- known as the sep pad - this may also need cleaning/replacing
Sep 06, 2013 | HP Designjet 70 InkJet Printer
I dont know what batteries to use and film to use on my minolta maxxum 70.
The Maxxum 70 uses two 3V CR2 lithium batteries.
The Maxxum 70 can use almost any 35mm film. Color prints, color slides, black-and-white prints. Do NOT use Polaroid instant film or infrared film.
If you need a manual, you can download one at
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_60/Dynax_60_Maxxum_70_E_B.pdf
Jan 26, 2011 | Minolta Maxxum 70 QD 35mm SLR Camera
Fault F12 Canon BJC-70
F12 = PrintHead Temperature Error
Try installing a NEW print head, if the problem continues the printer requires service
Jul 30, 2009 | Canon Office Equipment & Supplies
Flash won't work on Sony Cybershot T-70
multi shot mode would not have flash.
change back to single shot mode.
Nov 06, 2008 | Sony DSC-T70 Digital Camera
Sharp cash register a420
Hi.
I'd do a reding of your PLU list:
Turn key to PGM mode.
Type 1200 X 1 X 70 TL
This should print PLUs 1 to 70. If it all looks good and fits with the layout of the columns of your keyboard, then someone may have moved some item positions in the layout.
Are you using Job codes 1210, and 2214 for price, and Text?
Jun 26, 2008 | Casio Parts Cash Register PC Desktop
Won't turn on
No power, R640 open
Change R640, IC600 and associated electrolytic capacitor
Dead, fuse ok
Replace Q701 (P3NA80FI) with a P4NB80FI-mbr. Check Q702 (BC338). Replace R703 (5,6E, 5W), all components in supply. Check print for poor contacts
No power
Voltage not changing on pin 18 IC901 (SZM-368ET2)
Will not work, standby (red) LED flashing
C604 in the 12V line is bad
Nov 24, 2007 | Hitachi 70VS810 70" Rear Projection HDTV
jasbo
jasbo
