Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Unable to setup N Wireless Router in Apartment
I have been working to install a Belkin N Wireless Router in my apartment for the past few days, and I have been unsuccessful. When I try to go through the setup process, I run into different problems. Most of the time, I cannot get past the first stage of the setup assistant when the setup CD is checking for router and computer connections. When I do manage to get past this step, I typically make it to the screen "internet account info not accepted". To the best of my knowledge, I have submitted all the information accurately, and I have attempted the set up on both a DELL and a MacBook Pro.
Thanks,
Anna
    Problem Solver:
  • 12 Answers
Hi.
you do not have to run tye setup disk..
go to command prompt and do ipconfig
find the default gateway,launch internet explorer and in the address box type in the default gateway make sure the router is hardwired as sometimes it does not work on a wireless conection when you configure it.
If you get the router's console page it means that the router is getting detected(you can also ping the gateway on the command prompt to check the same)
on the console page you can fill all the settings and save them..the router will reboot and then you shold be able to use the router with proper internet and wireless settings.
http://www.ikarmatech.com
cheers.
Posted on Sep 11, 2009
Need passwword for belkin wireless router
Firstly you setup Belkin router for these easy steps
Few Things You Need Upfront To setup Belkin Wireless Router .
  • Internet Connection From Your Internet service Provider Like At&t, Comcast , Verizon Or Any Other Provider .
  • Ethernet Cable (Normal Internet Cable) Mostly RJ45 (For Connecting Modem To Belkin Router )
  • A Computer (Optional)
And now for recover your password follow these steps
Recover Belkin Router Password-
1 To Access Belkin Router Web Interface Open your Browser And Type 192.168.2.1 And Hit Enter .
2 Now Click On Login And Without Typing Any password Just Hit Submit . (Because Most of the time there is No password ) .
3.Now Go to Wireless At Left Hand Side And Click On Security And There You Can See Your Belkin Password
For more details setup Belkin router / Recover password kindly visit
How to Setup Belkin router Install Belkin Wireless router
How to Recover Lost Password for Belkin Router Fixingblog com
Good luck......
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
Haw can i install Belkin wireless router N300 without the CD
1- Let us connect a modem to the WAN or through a port of a modem of a Belkin router.
2- Now plug into a modem & a router with a power source
3- After that it requires your PC system with any one of its LAN or an Ethernet port of a Belkin router. Remember, if a user is connecting as wirelessly then it first need to connect via the Ethernet Cable.
4- At last, in the upper panel of a device. Customer can easily observe the LED light of your Belkin router. Need to wait for 10-15 minutes for turning the LED light into totally solid blue.
5- Verify the Belkin router connections are properly connected to a modem and an Ethernet cable.
6- Now power cycle the modem by getting unplugging it through the power point and then again wait for a while. After a 15-20 minutes, plugged it back to its power source.
7- Power cycle helps a user to re-connect or established the strong communication with a modem and a Belkin router. Thus, the method is now completed for how do I setup a Belkin Router without CD.
for more checkout...
Apr 10, 2012 | Belkin F5D7234-4 Router
How do you set a password for the wireless router after installation
I have a belkin router as well. in your address bar in you internet browqser (internet explorer, netscape, etc.) type in http://192.168.2.1 This will bring up your router configuration page. Go to the section that lets you set a password. (It is probably under wireless security) and set a password or "network key". If it asks what kind of security you want (eg. WPA, WEP, etc.) I would simply choose WPA. It is not the strongest security, but it is the easiest to setup and unless you live in a densely populated area ( e.g. new york apartment) it is all you should ever need. If you have any questions feel free to ask me at lilchicken_dean2@yahoo.com Hope I could help!
Nov 06, 2009 | Belkin (F5D8231-4) Wireless Router...
F5D7231-4 stopped connecting to Internet via downstream router
Why did you change it from dynamic to static? My suggestion would be to put it back to dynamic and let it grab a good ip address from the gateway. The other option is to contact whoever managed the network at your apartment and see what they will charge you for a static IP address.
May 23, 2009 | Belkin (F5D7231-4) Wireless Router
My apartment receives its internet connection via ethernet from an external router. I had been using the Belkin F5D7231-4 as a wireless router (not configured as an access point) but recently it dropped...
You don't want to set a static IP address in your wireless router. You'll be connected to the network alright, but the IP address won't be recognized by the primary router. Thus, you'll see you're connected with only local access.
First and foremost, ensure that your Internet connection is valid. Plug the ethernet cable from the wall directly into your computer and test the connection. If you can't get it to work, then the problem is not on your end. Contact the agency in charge of the external router (e.g. apartment maintenance).
If your connection is fine hard wired, you may have bad data or a faulty configuration in your wireless router. I suggest doing a complete hard reset (there should be some instructions with your router on how to do it--some have a small flush mounted button that you have to press for a few seconds). Set up your wireless router as if for the first time. This should take care of your problems.
May 23, 2009 | Computers & Internet
Connecting to the wireless router
You would have to consult your Motorola wireless router support
Have you tried this link ?
http://broadband.motorola.com/consumers/support/default.asp?supportSection=CableModems
Jan 18, 2009 | Arris Wireless G Broadband Router (wr850g)
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Problem with belkin router
assuming you are connecting wirelessly; you may have to check that the router is allocating ip addresses automatically to your pc's. connect one of your pc's to the router via the RJ45 network cable that was supplied and not wirelessly and type 192.168.2.1 in your internet browser, this will take you into the routers setup menu. Look for a menu refering to 'DHCP' and make sure that this is enabled, then look for the channel number that the router is using (normally 6 or 11) and make a note as if you are still experiencing signal loss, you can get back into the router and change to any channel between these numbers incase you are getting appliances interfering with the signal, save and exit from the router menu. disconnect the cable then go to control panel, network connections and right click on the connection you are using whether it is wired or wireles and click on properties. Look for the line TCP/IP and again click on the line and select properties, then make sure automatically obtain ip address is selected, ok and close window. Restart the pc's and you should have a connection.
Jul 08, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
391 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
