Question about LG WM1814CW Front Load Washer
Lg front load washer WM2301 will not drain
My washer doesn't seem to drain and I'm getting a OE error. I have drained the tub from the front drain, and then it works, but it's not draining out the back. The LG customer service thinks it might need to be leveled, but when I check the level it seems fine. Could this be a problem because I have it installed on the second floor of my house?
Drain hose may be bent or clogged, or the drain filter itself may be clogged
Posted on Sep 11, 2009
I have a tromm washer (model wm2277hw) that sometimes will drain and sometimes not. when it doesn't i get error message OE. all connections seem to be good. when it doesn't drain there is no noise like...
An OE error presents if the washing machine has not successfully drained the water in ten minutes. Follow this link for step by step instructions for correcting the OE error code.
The FixYa Team
Dec 27, 2010 | LG WM-2277HW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
OE ERROR CODE APPEARS ON DISPLAY ON MY LG FRONT LOAD WASHER
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages
Oct 14, 2009 | LG WM-2277HW Front Load Washer
My lg front load washer stops and give me an error message OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2009 | LG WM-2277HW Front Load Washer
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Mar 19, 2009 | LG WM-0532HW Front Load Washer
LG WM1814CW Front Load Washer Logo
971 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
