Question about Cycling
RATTLING FRONT SUSPENSION FORK : the fork is making an excessive rattling noise even over insignificant uneven surfaces The suspension appears to operate normally but i am concerned that the noise may lead to fork failure and be potentially dangerous. My cycle is a Raleigh Synchro manifactured in 2007 and the fork is a Suntour SR XCM. I have heard that the elastomer fitted to this model is notorious for hardening ?. Can i replace it or do i need to replace the whole fork. Thank you in advance. Regards Rob
Your folks may need new washers/sumps that are placed in the bottom to stop them from sinking
Posted on Sep 11, 2009
Rattling noise coming from front passenger side of my 2005 Passat when driving on uneven surfaces
Check the suspension, possible causes, ball joint, track rod end or anti roll bar linkage
Dec 02, 2015 | 2005 Volkswagen Passat
How can I cure the rattling noise on my i10 on rough road surfaces
look for loose rubbers on shockies, suspension points sway bar points , front and rear , check for loose muffler rubbers or faulty cat converter rattling inside , check for loose rocks under the heat shielding around the exhaust system.
May 06, 2014 | Cars & Trucks
Rattling noise
check the suspension and steering linkage, control arms, shocks struts and bushings
Jan 23, 2014 | 2007 Subaru Forester 2.5
Hi I have a rattling sound coming from my landrover freelander and the suspension feels no good at all the little humps in the road feel like they are a lot larger than they are but my question is is
LOL Check the bushes of the torque tension bar saddles. Either they are loose or the bushes are shot. The are located on the front axle and the saddles is fastened down on the cross member.
Jun 12, 2013 | Land Rover Freelander Cars & Trucks
My car makes a knocking or rattling sound on uneven road surfaces
Check the front suspension for worn or loose componets.
Jul 20, 2011 | 2002 Ford Escape
My 2000 FXDX Dyna Super Glide Sport has a rattling noise coming from the front end. Had it checked out but unable to locate source. Rattling noise happens when braking to slow down.
Check your rotor out closely. Look for a crack in it that runs from one hole to another. The holes are for cooling purposes but if the rotor gets too hot for one reason or another, it'll crack. When it heats up from the braking action, metal one either side of the crack becomes uneven and causes a "click, click, click" noise.
If you don't find any crack, first off that's good, But, then you need a dial indicator to check for warpage of the rotor. Mount the dial indicator on the fork slider and the spin the wheel with the dial indicator on it. Anymore thans a few thousandths could cause the rattle by moving the caliper side to side.
The rotor caliper is mounted so that it will move side to side and the pads are mounted inside so that they "float". They have anti-rattle clips and springs to keep the noise down. Make sure all these parts are in there and positioned properly.
Apr 20, 2010 | 2000 Harley Davidson FXDX Dyna Super Glide...
Adjusting front fork rebound damping screw
It sounds like your forks need servicing by a professional. Your instincts were right, they should be about equal length, so something BAD has happened to one of the forks. I would recommend going to a sport bike speed shop that specializes in suspension work to have this fixed since the guys at HD barely know how to change the spark plugs on a Buell in most cases.
A good shop can not only repair the damage, but help you to set the suspension exactly right for you (the Buell manual is just a ballpark setting) by checking the sag in the suspension, and they can even upgrrade your forks and shocks for you.
Arguably the best in the business is Max at traxxion dynamics. They have drop in cartridges that allow the showa forks to come close to the Ohlins used by the pros. Not that the showas are bad, In fact Buell always put decent factory suspension on their bikes, which is why it's repairable, instead of needing to replace it.
Feb 01, 2010 | 2003 Buell Lightning XB9S
Front End Rattling in 2006 Pontiac Pursuit
Sounds like a body weld issue ( as this is a unitized body design). Several US GM models prone to this. No real good cure.
Jan 15, 2010 | 2006 Pontiac G5
Loud noise
Check your exhaust and rear suspension for something loose or broken. Problem could be the exhaust, a hanger or cracked pipe. In the suspension it could be shocks, worn bushings, track arms etc. When a problem like this happens you have to get under the car and grab and try to move things checking for loosness. In general try to see what is loose enough that a bump causes it to rattle or bang. Other than inspecting the rear area there is no short cut that can be taken to solve the problem. You don't want to just start replacing parts hoping to fix the problem, that can be expxnsive and unnecessary. Good Luck!!!
Oct 13, 2009 | 2004 Mazda 3
Cycling Logo
179 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
