Once I send a fax, I am unable to send another without turning the machine off & back on. When I try to use it again to fax, the button beeps and the screen says busy.
    Scholar:
  • 44 Answers
What is the brand of your fax machine.... i have an hp officeject3500 series all in one...when im sending fax after it says 1 doc sent/faxed, it will take like a few mopre seconds before i cud use the handset or send a new one...
and also r u trying to send to a different number or the same???
if the same number and u want to send mutiple documents uve to prepare the docs ull be sending like after feeding the first page immediately feed the next one before 1st page is out of the machine..
dunno if this will help u but if check the setting and ifs okay maybe the best way or next step is to report it to a technician where u got ur fax machine...
Posted on Sep 12, 2009
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Hi, My office fax machine will not send or receive faxes, or make copies. I recently replaced the toner cartridge, and then the problems began. It keeps saying either printing online, or sending online,...
Sounds like a glitch in the memory has left a document there, unable to print. You'll need to clear it out by going into the Maintenance Mode. Maintenance Mode is not mentioned in your user's manual, because there are several functions available that can seriously disable the machine. All you have to do to be safe is follow these instructions to get into the mode, clear the memory, then get out without messing around with other functions.
Press these keys in rapid succession:
Menu
* (the star on the dialing keypad)
6
Do that whole sequence in 2 seconds or less, ignoring all the beeping the machine will assault you with. It's designed to not allow some to accidentally enter Maintenance Mode; if you wait for the beeping to stop, you'll fail, left in some part of the normal menus. When you succeed, the word MAINTENANCE will appear on the display, and all the lights will flash in unison. If that doesn't happen, just touch the STOP button and try again.
Once in maintenance Mode, touch 91 on the number pad. The display will say Initializing or something like that as it clears all the documents form the memory. Your programmed phone numbers and settings will not be affected. When it finishes it will go back to MAINTENANCE. Unplug the power for a few seconds, then plug it back in. The machine should be fine and ready to use.
If Function 91 doesn't work, you should try going back into MAINTENANCE and touch 01 instead. It will clear all memory back to the point it was when you first unboxed the machine. But I think 91 will take care of everything.
Feb 15, 2011 | Brother IntelliFax-4100e Fax
Unable to receive faxes
Make sure its set to fax only by pressing the function button and then recieve mode!Keep pressing recieve mode untill it says fax only and press set/ok!Try cleaning the big grey roller at the back of the machine!Good Luck!
Apr 13, 2010 | Canon FAXPHONE L80 Laser
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
No copy and send fax from adf unit
First try reseting the unit by holding the * key and the enter button and the same time turn it on until it starts beeping. This will rest the machine. If this does not work. you need ADF rollers the can be purchased for 20 to 25 bucks
May 08, 2008 | HP LaserJet 3380 All-In-One Printer
Fax unable to receive and send.
Some basic troubleshooting tips are listed below to help determine the cause.
Check the following items :
Ensure the phone cord is plugged directly from the wall jack, into the back port of the fax machine marked "Line", "To Wall Jack", or with a wall jack symbol
Remove any other device from the line such as splitters, credit card machines, or telephone answering machines and retry.
Turn Error Correction Mode (ECM) off ,
For turning off ECM > press set up > press ok >go to advanced fax set up by using the arrow key > press ok > press arrow key go to OFF > press ok .
After these steps > try to send a fax to undermentioned number , once it is sent u will recieve a confirmatory fax in return as well .
self confirmatory no for fax 1 888 473 2963 .
or u can try to send a fax to a different local number as well.
Thanks
Apr 25, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Material I'm trying to send doesn't 'feed'
does it try to grab the paper?
do you hear anything happening before the beep?
The machine recognises that there is paper, then you should hear the communication, once it has the correct signal telling it the line is available for transmission it will feed the paper.
look at the tires and see if they turn to feed the paper, is there something in the way, do the tires turn,???
if yes clean with alcohol and try again, if the tires are too smooth then they need to be changed.
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Solution to fix prolem with machine
Line interface unit is broken beacuse of which the beeping sound comes up. It tries to intiate however fails as a result the sound comes up. Need to replace the printer.
Dec 06, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
Paper jam and fax in memory
Just unplug the power cable in your machine and put it back again.The paper jam will clear but...also the fax memory will be clear at the same time.just tel the other line to re-send thier fax again.
Oct 04, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
BEEP, BEEP,BEEP
The Start Button can become stuck on these very easily. If it is stuck, then press it down and it should jump back.
Jan 31, 2007 | Brother IntelliFax-2820 Laser Fax
54 people viewed this question
k24674
jasbo
jasbo
