Question about Samsung Yepp YP-T7JX MP3 Player
This thing is frozen
Everytime i try to turn it on it says not enough space for database delete more than 4.0MB and then the screen lights up and it freezes at samsung so i can't get on to delete anything what do i do
0 characters
1 Points
When turning on my sansa e250, the msg "Refresh Database" and "Not enough space for music DB. Please free 6MB" display on the screen. How do I do that?
Remove the microSD card, then connect the player to your computer and delete stuff from its internal memory until you have 6MB free.
Jan 26, 2010 | SanDisk Sansa e250 MP3 Player
After changing out the battery, i turned it on and
The database seems to be overloaded while rebuilding the files info and playlists.
See the answer for "Not enough space for MusicDB" :
For the c100 series connect the player to the computer how to delete files see:
When linked to the computer there are 2 different connection modes possible:
  • MSC mode seeing the player as a removable disk using Windows Explorer.
  • MTP mode seeing the Sansa player as a Media device using software like Windows Media Player.
For "cleaning up" your database check both lists. How to switch to MSC / MTP mode:
Manual for Sansa c100 series:
Sep 28, 2009 | SanDisk Sansa c140 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
Not enough space for music db. Please free 6 MB.
If you have formatted there is no music on the player. You will have to re-sync any the music. Set the USB mode to MTP, then Use Windows Media Player 10 or higher to sync player.
Apr 03, 2009 | SanDisk Sansa e260 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Frozen screen
Well you could do wut i did. i threw it onthe ground and now it works again. Everytime it does it to me i drop it and it works again.
Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
Cant turn on player
Well plug it into the computer right click on the sansa clip and format it if it wont start then restart it by holding powre for about 10 seconds or so. then try to turn it on...if the thing still wont work download jet audio.(
and once thats done. you should take all your music on the mp3 and put it onto the desktop in a folder named MUSIC then highlight all the music right click should say somthing about jet audio and edit tag with jet audio then delete Tags....i know this will be the crppiest thing to do cause you have to fill in all the info. this also fixes the frozen refreshing database thing. hope it works
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
Music DB??? clear 6 MB???
Have you tried re-formatting the device?  This will "wipe" memory, getting rid of corrupted files, etc. and should restore use.
Oct 24, 2007 | SanDisk Sansa e250 MP3 Player
'no database'
The Database error is generally because the device does not have enough free space to create the database ( or GUI ). Delete some songs off the device and that should solve it. You should generally keep 6MB free for every 2 gigs of music. Please add to the question for additional assistance. Best of Luck.
Oct 02, 2007 | Sony NW-E002 MP3 Player
Samsung Yepp YP-T7JX MP3 Player Logo
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
