Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Cannot stop water from running out of dispenser
  • 736 Answers
When you push on the lever (that normally should release water) .. does it click .. if it does then you have a stuck solonoid operated valve .. thats located at the bottom in the back of the refrigerator (behind a cardboard cover) .. there are two valves ganged together .. one is for ice the other for water .. you can try tapping on the valve assembly to see if you can free it .. if not then you have to replace it ..
now if operating the lever does not cause a click sound then you could have a bad or stuck switch (just behind the lever) .. a stuck valve is more common ..
Posted on Sep 12, 2009
Howto repair refrigerator water dispenser
There is an electric water valve, usually at the lower back of the appliance which would appear to be stuck open and would need to be replaced OR the switch in the dispenser area is stuck in the closed position. Try disconnecting the wiring to the valve and if that stops it then most likely the dispenser switch is defective, If not then the valve is likely stuck open. There should also be a small valve in the water supply line, under a sink or etc. that you can shut off to stop the water flow with until you get the other problem daiagnosed and fixed.
Sep 08, 2014 | Hotpoint Refrigerators
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
The water from the dispenser is running and i can't stop it how do you turn of???
The cause of the problem you describe could be ether water inlet valve or the water lever dispenser switch.Locate the water valve at the back of the refrigerator, open the water and take off both plugs from the valve. If the water flow want stop replace the water valve. If it will, replace the water lever switch.
Mar 24, 2013 | GE GSL25JFPBS Side by Side Refrigerator
Water won't stop coming out from the cold water dispenser
The cold water dispensing valve can be stuck or defective. Sometimes jiggling the valve can make it stop running
Sep 30, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water would not stop running into icemaker, now
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Mar 25, 2010 | Refrigerators
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
WATER RUNS OUT OF THE WATER DISPENSER ON THE DOOR OF THE SIDE BY SIDE
THe problem may be in the water valve for the water despenser,
you could try disconnecting the 2 wires on top of the water despenser side of the valve and see if that will stop it. IF not the valve may need replaceing, may be leaking thu water vavle when closed
Oct 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
