When I connect my wireless router to my computer the speedtouch cannot be detected by my computer therefore I have no internet on my computer but I have wireless on both laptops which are directed through the router???????????
  • Matt B
    Matt B May 11, 2010
    Slow down a little. :) Please induldge us a little more information... What OS are you using? Which model of Speed Touch wireless router? What is your internet source? ADSL? I can't quite puzzle out, are your laptops able to access the internet? Or is just your desktop unable to access the internet? What kind of security settings do you have on your router? (Out of curiosity, it might not even be applicable) Thanks. :) Not a Speed Touch expert, but we'll see what can be done.
  • aana_2k2 May 11, 2010
    please give some more setup details as how the router,modem and the computers are connected with each other.
  • 3 Answers
You probably have the router set to static ip so first you have to assign your pc with an ip range of the router , then log in the router set to dynamic ip and make sure you connect cables as per router manual. if it does not work then disable firewall , enable upnp devices . After configuration of wireless router you can enable firewall again. If you are using vpn with speedtouch then you should configure speedtouch to store username and password to connect to isp
Posted on Sep 11, 2009
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
Hi all I have a Thomson Router ST585v6sl. I can connect to internet via cable but not wireless. Wireless light when you turn router on is red then goes out. I can't find an option in the routers...
i have one try using an ethernet cable and put in on internet explorer
192.168.1.254 That should be the speedtouch routers page
don't click the tabs on the right scroll down and find home networks there should be two options wireless and ethernet along with all the connections click wireless (if you cant click it click the home network tab then interfaces then click your router) then in the top right there should be something called configure now this is how it should be
Interface Enabled : Ticked
Network Name (Your Routers Name)
Interface Type: 802.11b/g
Channel Selection: Manual
Allow Multicast from broadband network: ticked
Broadcast Network name: Ticked
Allow New Devices: New Stations allowed automatically
Encryption : Use WPA-PSK Encryption
WPA-PSK Encryption Key: (Any Password thats memorable)
WPA-PSK Version: WPA
Apply if theres any changes (hopefully) try that if fails try one of these three steps:
1. go on 192.168.1.254 then click the speedtouch tab then click return to factory default settings to return it to the way you had it when you first got it. (WARNING: If you dont have your internet password you will have to call AOL for it)
2. Buy a HomePlug which is an ethernet cable that uses the electric wires in your house (example. http://www.amazon.co.uk/D-Link-DHP-307AV-PowerLine-Homeplug-Network/dp/B003L78F6U/ref=sr_1_11?ie=UTF8&qid=1298768566&sr=8-11)
3. Scrap the router and try a different one thats what i did well.. my speedtouch kept crashing and i couldnt hack it anymore now i have a new router and it was the best move i did.
Hope it works for you!
Ryan
2.
Feb 09, 2011 | General Computers & Internet
I have a thompson speedtouch 510 that works just fine but when i add my SPARKLan WRTR-141 it wont get connected neither by the computer or the laptop. i have 2 ethernet cables i added one end of the first...
Have you gone into the SPARKLan and configured it yet? It should be like this Speedtouch>SPARKLan>your computer in to the SPARKLan.
Turn on your new routers SSID so it can be "found" by the wireless devices. You should turn OFF the DHCP server in the Speedtouch and turn DHCP ON in the SPARKLan.
Hope this helps.
Jan 13, 2009 | Computers & Internet
Wireless router problem help fast plz
connected the CST-5 in the following manner.
1). one cable from speedtouch LAN port to sparklan WAN port
2). one cable from sparklan LAN port to the computer network port.
3). disable the DHCP from the parklan (consult your users manual how to do that).
4). restart all of the equipment in the following order. (This is important)
speedtouch, sparklan, computer, laptop.
do not rate the answer till you have the whole thing figure out.
Jan 13, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Wireless
Whats the exact model # of the Speedtouch?
Well if your Modem doesn't have a WAN for a network cable (RJ-45) if all it has is a usb for connecting to a PC only I hope you have WindowsXP or Vista. Well what you can do is use your PC as a gateway like... What you would need to do is Plug the speedtouch into your PC with the usb... Plug the WAN from your router into your PC's network jack. Now you can go and do the Wireless/Network setup wizard and tell it your using a PC to connect other PC's to the net.
May 02, 2008 | 3Com OfficeConnect Router
Belkin (F5D7633-4) Wireless Router and SpeedTouch 360
I have solved this issues. I simply had to change the VPI/VCI values which i have obtained from my ISP. These value differ from one ISP to another.
Thanks for all the people tried to help me!
Mar 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
