Question about Sharp AL 1631 Copier
HP Officejet 7310 AllInOne. 1.Had paper jam, carefully removed jam. (happens from time to time no prob). 2. Prob - after this latest jam, paper feeder no longer works properly. 3. When printer feeder takes in sheet of paper, it's like one side of the intake pulls harder (my left side) which bunches the paper and creates a paper jam, every time. I did feed a thicker paper through to clear the way in case something was jammed, but there doesn't appear to be anything stuck in there. Passage is clear. Any ideas? Thanks.
    Guru:
  • 389 Answers
There is idea.. Vernee decision. Every time, when аa paper stuck you its remoove most often aptly. However this trouble meets in printers HP((. Prizhimnoy roller of the presenting the paper has distorted, he came out of its place or axis of the roller or rubber roller, be brake platform cost(stand)s not exactly, this that platform that under roller. Nothing else be can not. Thank you that so have well described the fault. If you to manage most see the jaggy of the roller of the presenting the paper, you understand, there all very frail and such could happen, Else brake platform from below under spring - this spring stress in platform from below on the centre exactly or two springs then they cost(stand) in symmetry, you it is necessary пробывать press on brake platform and come to a conclusion, has she even striking on the centre. Thank you
Posted on Sep 16, 2009
HP OfficeJet 7310 All-In-One Carriage Jam
I think you need to clean the back rollers of the printer.
Follow this hp document and it should clear up the issue. The error is for out of paper but the fix is the same. Step four is the one you need.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&jumpid=ot_recdoc/c00219180/en_us/c00786157/loc:4&custom_solutionid=rd_c00219180&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=391182
Jan 28, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310 allinone
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp 7310
Find the stuck piece of paper and remove it.
Dec 21, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 printing crooked. New HP cart installed.
There is a back panel that opens up by turning a knob....remove that panel and view for any paper pieces...
keep me posted if this didn't help!
Nov 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Mar 10, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310
showing paper jam and have checked and don't see any paper
Dec 17, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder is jammed and doesn't copy or fax
Is it jammeded or is it simply a warning saying it is?
Remove all paper and attempt a paper feed without paper.
The paper feed and delivery trays are removable so remove them and carefully reset them.
Making sure the paper is well fanned reload and retry.
Come back with the result.
Dec 13, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Sharp AL 1631 Copier Logo
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
