Question about Singer 8280 Mechanical Sewing Machine
Kenmore 12110 Top thread is tangling in bobbin
  • 27 Answers
Lack of top tension. Raise presserfoot and rethread the top of the machine. Allso check for a bur on the hook.
Posted on Feb 23, 2008
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Kenmore 158 12271
the bobbin case is not located properly. take it out check the bobbin fits fully inside it.
Feb 18, 2014 | Sewing Machines
Tangled thread on wrong side of fabric, I did the remedy as per manual but problem still exist
Unthread the machine fully. Remove the bobbin. Is the bobbin thread the same as the top thread? Is it a Quality thread (yes, cheapie thread can give big issues!!) Do you have several different threads wound onto the bobbin?? Is the bobbin thread wound on quite tight? If you push your finger nail into the thread wound onto the bobbin, it must not feel soft or spongy. Check if there is any roughness / burr on the any part of the shuttle hook. If so, remove it with 800 grade wet and dry abrasive or similar. Put in a NEW needle as per user manual specs (not a 'new' one you used before 'just for a little bit'.!) REPEAT - put in a NEW needle - amuse me!!. Place the bobbin into the bobbin holder (the CORRECT direction - yes there is a Right and a Wrong direction!), thread it ready to put back into the machine. BEFORE you do, hold onto the thread tail and let the bobbin and bobbin case dangle. Thread should slip thru when you give a gentle pull upwards. If no slip, loosen the tension on the tension finger a LITTLE. If it slides down easy, tighten it a little. Fit the bobbin into the machine. Lift the presser foot (this releases the top thread tension discs) Check there are no bits of thread or fluff between the tension discs Rethread the top thread - check the thread path is 100% correct. Hold onto the end of the needle thread and draw up the bobbin thread. Hold both threads, start to sew - check the result. Tip : If you use a different color bobbin thread (same brand etc etc) it will help you to see more easily what is going on. You should be seeing some of the bobbin thread color on the top side of the sewing. If not, INCREASE top tension a little - retry.If there is a lot showing, decrease top tension. Good luck
Dec 14, 2012 | Sewing Machines
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Kenmore 148 bobbin thread ends up a snarl under the cloth. Seems like thread is not coming off bobbin smoothly or measured, ending up with tangle and stopping.
Usually it is your top threading or your needle needs to be changed. Rethread paying close attention that the thread is in the tension discs right. Try with presser foot up, pull thread, it should pull smoothly, now put the presser foot down, it should barely move. This usually seats the thread in the tension discs.
Jan 01, 2011 | Kenmore Sewing Machines
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
My machine will only sew a stich or two then the motor still goes, but the feed dog and needle get stuck like the top thread is tangling with the bobbin. How can I fix that?
check you needle to see if it's damaged
check to see if the top thread to see if it's come off the thread take up lever
check to make sure there's no lint or loose thread in the bobbin area
Sep 30, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Bobbin tangle
can not thread bobbin...bobbin on top
Jan 16, 2008 | Kenmore 19233 Computerized Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
63 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
