Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Last week the refrigerator side of my side by side started to freeze everything. So we defrosted it and now it does not seem to be getting cold. My freezer is fine.
  • beamerguy740
    beamerguy740 May 11, 2010
    Model # and manufacture date?
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
My fridge has been having trouble maintaining the correct cold tempt the last 2 or 3 weeks causing my food to spoil. any ideas what can be causing this drop in temp? thanks!!
Check your condenser grill to make sure that air can circulate around it.
If you are getting an ice build up on the inside of the freezer, it is more likely the defrost assembly. Suggest you turn off the refrigerator and then completely defrost it. When it is defrosted, then plug it back in. If everything starts to function again and freezes, then it is most likely your defrost circuit, which is an assembly. Not that hard to replace and not that expensive to do yourself. Just take your time and make sure the unit is unplugged from electricity.
Jun 01, 2011 | Kenmore 56983 Side by Side Refrigerator
FREEZER SEEMS TO RAISE IN TEMP. AND ICE STARTS THAWING THEN STARTS FREEZING AGAIN. FRIDGE SIDE SEEMS NOT AS COLD ALSO.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Whirlpool ED2GHEXN Side by Side...
The refrigerator side started not cooling last week just half way up the fridge. Now the freezer half way up is not freezing.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
dhjhdg
Oct 26, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
Kenmore cold spot
The reason to this problem can be due to the
faulty defrost.
Sep 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Each side won't get cold. food starts to spoil
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coil freezes
perhaps the drain is plugged in the freezer.
Have you checked this, please let me know what you find and we can go from there to figure this out.
May 12, 2008 | Hotpoint HSS25GFP Side by Side...
Freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Aug 28, 2006 | Kenmore 50522 / 50524 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
