Question about Cell Phones
I had my transmission flushed and filled last week. I have 36000 miles on my titan 4wd, 5.6l engine. The transmission is now slipping. The oil lube shop put in penzoil multi-vehicle ATF. Could this have caused a problem so soon ( less than 500 miles)? When I called them on Tuesday they agreed to change the oil out to Matic-J from Nissan. This has been done but the xmission still slips under power. No slipping in normal traffic without a trailer.
2006 Cadillac cts is burning gas faster than the normal rate after i got an oil change at jiffy lube 2 weeks ago
I dont think there is a connection between an oil change and the gallons per mile.
With that age car, I suggest a Terra engine clean. It will blow away nine years of gunk from the spark plugs, fuel injectors, cylinders and exhaust. Should give you more power, more miles..
Mar 18, 2014 | Cadillac CTS Cars & Trucks
My 2006 Nissan Titan Slip light comes on at start up. At this time, the 4wd display tree in dash is not showing up. After truck warms up at idle for several minutes, or is driven for a couple miles, the...
Most likely a wheel speed sensor starting to go bad, possably a wiring or Modual Issue.
You would have to pull the code with the light lit to tell you were to start the Diagnosis.
Oct 23, 2013 | 2006 Nissan Titan
Got oil change done at Jiffy Lube. I got my transmission flushed & refilled last month. Now Jiffy Lube is saying I got a little transmission leak caused by wear & tear. How much you think it should...
unfortunately sometimes when you get the engine or transmission flushed it can cause an oil leak I don't know what it will cost but I would be getting other quotes & get the work done at the cheapest quote, it pays to shop around........hope this helps......cheers.
Sep 24, 2011 | 2006 Pontiac Grand Prix
How often should I change the Transmission fluid, normal driving ? Thank you Gary
It's listed in your owner's manual. Schedule A is normal driving conditions.
SCHEDULE "A"
7,500 miles (12 000km) or at 6 months
- Change engine oil.
- Replace engine oil filter.
15,000 miles (24 000km) or at 12 months
22,500 miles (36 000km) or at 18 months
- Inspect front wheel bearings.
- Inspect brake linings.
30,000 miles (48 000km) or at 24 months
- Replace engine air cleaner filter.
- Replace spark plugs.
- Drain and refill automatic transmission fluid and filter (4.7L).
37,500 miles (60 000km) or at 30 months
- Drain and refill automatic transmission fluid and filter (5.2L/5.9L).
- Drain and refill transfer case fluid.
45,000 miles (72 000km) or at 36 months
- Flush and replace engine coolant at 36 months, regardless of mileage.
52,500 miles (84 000km) or at 42 months
- Flush and replace engine coolant if not done at 46 months.
60,000 miles (96 000km) or at 48 months
- Replace ignition cables (5.2L/5.9L).
- Inspect PCV valve, replace as necessary.
- Inspect auto tension drive belt and replace as necessary (5.2L/5.9L).
- Drain and refill automatic transmission fluid (4.7L).
67,500 miles (108 000km) or at 54 months
75,000 miles (120 000km) or at 60 months
- Drain and refill transfer case.
- Flush and replace engine coolant if it has been 30,000miles (48 000km) or 24 months since last change.
- Inspect auto tension drive belt and replace if required.
82,500 miles (132 000km) or at 66 months
90,000 miles (144 000km) or at 72 months
- Inspect auto tension drive belt and replace as necessary.
97,500 miles (156 000km) or at 78 months
105,000 miles (168 000km) or at 84 months
- Flush and replace engine coolant if it has been 30,000 miles (48 000km) or 24 months since last change.
112,500 miles (181 000km) or at 90 months
120,000 miles (192 000km) or at 96 months
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2001 Dodge Durango
What is the routine service schedule for 2006 jetta?
oil/filter/lube every 3,500 miles synthetic oils every 5,000 miles
tire rotation wheel align check balance every 7500 miles
transmission service every 30,000 miles
air filter gas filter cabin air filter evry 30,000 miles
if engine has a timing belt(rubber substance) replace every 60,000 miles if it has a metal timing chain lasts almost forever
spark plugs should be good for 75,000-100,000 miles before replacing
Spark plug wires every 50,000-60,000 miles approx.
fuel injector flush every 30-40,000 miles approx.
Aug 12, 2010 | 2006 Volkswagen Jetta
Please advise me proper maintenance for 2007 jeep liberty sport 36000 mile. last service (34000) it was a list of supposed required stuff to do. just want to know what is needed and not. thanks
I don't know how much maintenace you have done in the past. Besides the normal inspections of the brakes, fluid levels and oil changes they do recomend changing the spark plugs and the axle fluid at 30,000 miles and adjusting your parking brake cable. hope this helps....
Jan 20, 2010 | 2007 Jeep Liberty Sport
Should i change the differential oil at 125000.miles in my 2006
Yes and this easy to do. Just drain at bottom fill at top.
Mar 05, 2009 | 2006 Nissan Titan
I have a 2003 Yukon XL with 70K miles. What maintenance is required.
coolant flush and fill.. differential oil changed out ( assuming you have done trans service already also ) .. driveline (u-joints) and steering linkage lubed , fuel filter(s)..and all belts /hoses inspected ... have fun :)
Oct 20, 2008 | 2003 GMC Yukon XL
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
