Question about HTC Touch P3450 Smartphone
HTC TOUCH PHONE GETS SWITCH OFF WHEN PUT IN THE JEANS POCKET
  • 18 Answers
It is very simple i hope you select the two option in battery menu option.
in battery menu option following two line are avialable uncheck them.
"shut down if cell not work on internal power"
"shut down if cell not work on external power"
Posted on Sep 11, 2009
Just got this phone used. Touch screen does not respond. Everything else seems to function
Touch screen phone are too sensitive, common causes are when dropped on the ground,water damage and pressed by inserting it on fitted jeans or pants pocket. once even one portion is not working,they are not repairable, indeed need a replacement.you can ask assistance to any mobile service shop near you.
Jun 27, 2011 | Samsung SGH-A877 Impression Cell Phone
HTC getting hanged again & again
SAVE UR IMPORTANT DATA FROM PHONE & THEN RESET THE PHONE FROM COVER UR BACK COVER FROM BATTERY.
UR PHONE WILL BECOME IN FRESH CONDITION.
Jan 31, 2010 | HTC Touch P3450 Smartphone
If I put my HTC Touch on the table a bit hard it shuts down... If I put it in my pocket "and most times after I have sat down" it has shut down... Any Ideas... my guess is that the battery in disengaging...
Yes i agree with you the bat could be disengaging from the Bat contacts but I want you to get a new housing for the phone sometimes the back cover can be loose as in when u place it hard on the table or pocket it loosens .
good luck
Oct 06, 2009 | HTC Touch HD Smartphone
Touch Screen is not working
Since this is the case you may need to soft reset the phone.
The touch screens normally give problems whenever there is a little pressure applied to its surface e.g when you don't use a pouch but place the phone in a tight jeans pocket and thus will need,screen reallignment.As you may already know.
Now your phone has a soft reset function...try it! Or turn it off,remove the battery (not immediately! so you don't loose your settings then re-insert it after 25 secs.) and do a restart. This should allow you access the screen allignment settings so that you could fix your screen.
Hope this helps.
Sep 23, 2009 | HTC XV6900 Cell Phone
Pocket Quicken 2.5 and Windows Mobile 6.1
I finally got an answer from Landware: Pocket Quicken is comptabile with Windows Mobile phone operated with touch screens only.
Cheers
Sep 06, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
My I-mate touch Sacreen is not working
Reset your phone! and if you dont mind loosing your information run a complete reset.Then do a screen re-allignment.
To avoid a future re occurence avoid placing your phone in your tight jeans pocket so that you don't apply pressure to the screen.
Aug 02, 2009 | i-mate JAM Pocket PC
I have aHTC P3400 Pocket PC . Now the phone in off position . I Cannot switch on it. A red LED in top is seem.
hi when a red led is in view i would suggest fully charge as led should show green on power up
Jul 28, 2009 | HTC Touch Cellular Phone
How to install themes
Here is your Pocket PC's default theme
wm6_default.jpg 1. Connect your Pocket PC to your Desktop using your cradle and Microsoft Active Sync, Once it is Connected double click on the green circle on your taskbar to open the Active Sync Window (If the Circle is grey, then it means that your Pocket PC is not properly connected).
2. Now you need to click on the explore Icon.
3. Here you can see the files and folders on your Pocket PC. Navigate to the “My Documents” folder. (This is where we suggest that you put your themes) . You can also use the“Windows” folder or Main directory of a storage card (not in a sub directory).
4.Now you need to drag the TSK theme files that you have chosen from your desktop computer to your pocket pc 5.Now you need to activate the theme file on your Pocket PC:
Tap Start, Settings, Today, Select your chosen theme, and tap OK.
Your new theme will now be activated.
You can download the themes from: http://www.htcfreeware.com/HTC/categories/HTC-Themes.aspx
Jul 14, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch P3450 Smartphone Logo
85 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
