Question about Jabra BT250 Consumer Headset
Hi just bought a new jabra bt250v off ebay put it in craddle and it will not charge blue light does not come on tryed in my other craddle still doess not work any idears thanks mark
    Problem Solver:
  • 16 Answers
I have been in the same boat there is an answer on the site the battery has failed and is non repalceable. It can be jump started as suggested in the article.
Posted on Jan 07, 2010
Loss of charger for Jabra BT 200
hello,buy travel charger BT200/BT250/BT250V and you will have your bluetooth headset charging back.
Take care.
Apr 10, 2010 | Jabra FreeSpeak BT200 Consumer Headset
I have been given a Jabra BT 250v hands free head set
It should have come with a small 45 mm diameter cradle base unit which the mains has a 1.4 mm jack plug plugs in and the headset rests in.
Look for it on Jabra support website or pictures on a search on Ebay
Search on Ebay for one for a replacement.
Dec 26, 2009 | Jabra BT250 Consumer Headset
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
BT250V battery
The battery is not replacable.
Jul 25, 2008 | Jabra BT250 Consumer Headset
JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Jun 18, 2008 | Jabra BT250 Consumer Headset
New jabra 350 can't be charged
right out of the box i had the light flicker on me too. if you don't have warranty or receipt like i did try this. i'm not responsible if it doesn't work after!
peel off the blue part of plastic that has jabra on it. take a screwdriver and unscrew the star screws. take the cover off. using some wires, briefly connect a battery (i used a wireless drill battery) to the leads of the bluetooth battery. you'll see a spark.
now my thing is charging for the first time
May 24, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Sep 28, 2007 | Jabra BT250 Consumer Headset
Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Aug 30, 2007 | Jabra BT250 Consumer Headset
Jabra BT250 Consumer Headset Logo
126 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
