Question about Singer 8280 Mechanical Sewing Machine
Machine jams after a few stitches
My machine is less than a year old and intermitently decides to jam after just a few stitches. It appears that the upper thread is getting caught somewhere below the needle plate and wrapping around multiple times until the needle can no longer move. When this happens the machine stops very suddenly. I've adjusted upper and lower thread tension with no success. At first cleaning and oiling the hook fixed the problem, but that doesn't seem to help any more. Is it possible that my tension adjuster is broken? I'd love to try any ideas you can share! My machine is less than a year old and intermitently decides to jam after just a few stitches. It appears that the upper thread is getting caught somewhere below the needle plate and wrapping around multiple times until the needle can no longer move. When this happens the machine stops very suddenly. I've adjusted upper and lower thread tension with no success. At first cleaning and oiling the hook fixed the problem, but that doesn't seem to help any more. Is it possible that my tension adjuster is broken? I'd love to try any ideas you can
    Sergeant:
    Champion:
  • 298 Answers
Have you changed the needle lately
Posted on Dec 10, 2007
    Scholar:
  • 151 Answers
It's possible that the tension adjustment is busted, although I tried proper tension settings for my cousins same model which she was frustrated about when it keeps jamming, but following the manuals guide to tension adjustment helped solved the problem.
So here are some tips:
1. Read the manual for thread/bobbin loading. This is a crucial task that should be paid attention to. If not followed properly you'll be frustrated with jams and balled up threads. Just make sure to follow ALL the steps for threading the needle.
2. Adjust the bobbin tension properly according to the manual. It saved my cousin a lot of frustration...
3. Make sure tension level matches the fabric, level 4 seems to be good setting for most sewing needs
5. Also make sure to use good thread, it's a little picky with threads
2 Suggested Answers
  • 192 Answers
SOURCE: machine jams after a few stitches
Take a few stitches and look for where the thread is hanging as the loop slides over the bobbin case. If there is a rough spot causing it to hang, smooth it out with very fine steel wool make certain to remove all remains of the steel wool when you are finished. If the thread is catching between the bobbin case and some other surface, the clearance between the surfaces needs to be set and you should take it to a qualified repairman.
Posted on Nov 14, 2007
After stitching few stitches my machine snger 8280 get jammed
Not being there, I have to guess, but my guess is, your bobbin case is not set in properly, or you have a badly wound bobbin that's causing the jamming.
Another possibility is you have threads wrapped around the tension unit on the inside.
Jan 19, 2016 | Singer 8280 Mechanical Sewing Machine
My machine is new (only used once) but now keeps jamming, appears the needle keeps jamming under the plate,please help.
if it' still under warrenty take it back and get another..if it's not under warrenty, try a new needle, make sure the top thread is not coming off the thread take up lever, make sure the bobbin is turned the right way in the bobbin case, also could be a timing problem
Dec 03, 2014 | Sewing Machines
My old machine has jammed and cannot stitch
You need to take the bobbin case out to check thouroughly for a piece of thread that may be stuck, that is usually the answer.
Jun 10, 2010 | Sewing Machines
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
New Janome 6600 Erroring out
This is the official Janome reference to your E% error message:
Feed sensor error "E 5" appears when the machine is turned backwords slightly while the machine runs over tight spot. The above will happen when - the machine is locked by thread jammed in the machine. - sewing extreamly thick fabric. In case of the MC4900, it will happen when running without threading the thread take up lever. The thread take up lever should be threaded when the threading light lights up.
Hioe this helps
Bargain Box
Sep 27, 2009 | Janome Memory Craft 5700
Thread tangling and jamming under the plate
Sorry I do not have a solution but my Euro-Pro 1925 is doing the exact same thing yours is. Are you also getting a clicking sound and loose stitches on the bobbin side of the fabric? If you find anything out please let me know and I will do the same. I love my machine but I will never own another Euro-Pro product. I think the company sucks and does not stand behind their products. You can not find anything on the 1925 model and no one that can service it either. Thank you, Erica my email is erica_jennings@sbcglobal.net Funny thing is my machine is only 3 years old.
Jan 04, 2009 | Euro-Pro 9125 Computerized Sewing Machine
Apr 21, 2007 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
725 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
