Question about Whirlpool Accubake SF362LXTS Kitchen Range
On/off cycle of gas ovens
Do all gas ovens cycle on and off during baking to maintain temperature?
  • becky_jay966 Sep 11, 2009
    Thanks. Why do some gas ovens use mercury valves and some don't?
  • 3,600 Answers
Yes it is how it maitains the temprature you select, there is a thermal bulb that detects the temprature and helps to keep it stable.
Posted on Sep 11, 2009
  • Bruce Hathcock Oct 18, 2009
    Sorry it so long to answer but the ones with murcery switchs tend to outlive the mechaical ones as there is noting wearing out, on ingiters the tip ends to wear out over time like a spark plug.
Bake element wont cycle the temperature
PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204143.pdf
Note: The oven function will not work if the time of day clock is not set. ... The ovencan be programmed for any temperature from 170°F to 550°F (77°C to ... Can be used with BAKE TIME to program a delayed bake cycle. Timer Pad- Used to.
[PDF]ELECTRONIC OVEN CONTROL Control Pad ... - Frigidaire
manuals.frigidaire.com/prodinfo_pdf/Lassomption/318204125.pdf
cycle. Bake Time- Use to enter the length of the baking time. Timer ON/. OFF- Use.... It does not disable the clock, Kitchen Timer or the interior oven lights. TIMED. DOOR .... The Preheat feature will bring the oven up to temperature and.
Gas Oven Repair Manual - Chapter 6 ' Gas Ovens Manuals
www.appliancerepair.net/oven-repair-6.html
If it does not ignite, you certainly do not want the gas valve to stay open. ... these sensor bulbs do not cycle the burner on and off to maintain oven temperature.
How To Fix An Oven Door That Won't Open After A Self ...
Jan 28, 2016 | Frigidaire Kitchen Ranges
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Why did my oven light go off and then came back on then went out again,but the bake light stayed on?
I assume you mean the internal oven light when you say 'bake' light. If so, the oven light you are referring to is the oven indicator light. When the element is receiving power the oven indicator light will be on. When it's not receiving power it will be off. The oven thermostat controls power to the element and the power cycles on and off during cooking so as to maintain the required temperature. This is a normal occurrence.
Feb 26, 2011 | Kenmore 46123 Stainless Steel Electric...
Electric oven will not maintain temperature. drops 20 degrees
Jump online & get the schematics for your oven.. You'll need to troubleshoot the bake circuit, which is comprised of 2 - 120VAC legs (240VAC is applied during bake). One 120VAC leg is from the DLB relay and the other is from the Bake relay. if either one is bad, or not energizing, you won't get any power to the bake element. (The bake element runs 100% of the time during the bake cycle. broiler only operates 25% of the time during bake) I have had luck re-soldering the relay leg nodes on the backside of the relay board, as they develop "opens" over time. The relays are designed for ridiculous ##s of cycles, so they're not *usually* bad.
Dec 23, 2009 | Amana AOCS3040 Electric Single Oven
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then...
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Apr 07, 2008 | Kitchen Ranges
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
GE Profile Spectra JGBP85
Yes, it could very well be an igniter. The igniter can still glow and not work. The reason being that the igniter (depending on type) needs to produce .25 to .37 amps in order for the gas valve to open. If this potential is never reached, the igniter will glow, but gas will never flow. Or, gas will eventually flow for a weak (slow) igniter and will take forever to ignite. Which could be the reason for your low bake temperature. The burner does not stay lit all the time during the bake cycle. It will cycle on and off as needed to maintain the oven temperature. If the igniter is taking a long time to relight the burner, it could take a long time to heat. The broiler has a separate igniter and probably doesn't get used as often as the bake igniter. You can test the theory by swapping the igniter between the bake and broil burners and see if the problem moves to the broiler. Make sure you secure power to the range BEFORE attempting to remove the igniter, however. You should not have to turn off the gas to do this. Everything should be accessible through the oven door and broiler. I tell you this, because a new igniter (depending on the type you have) can run as much as $100. It will probably be worth the effort just to be sure. I hope this helps you.
Jul 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Accubake SF362LXTS Kitchen Range Logo
259 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
