Question about Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive
Just transfered hard drive to another computer - in setup- need to know capacity, cylinders, heads, sectors
    President:
  • 1,187 Answers
The specs are:
Capacity (unformatted/formatted):
20.00 GB / 15.02 GB
Cylinders: 16,383
Heads: 16
Sectors: 63
Here is a PDF w/specs
Fireball lct15
(http://www.dll.com.mx/biblioteca/HDD/Quantum/Fireball%20LCT15.pdf)
Hope this helps!
Posted on Sep 11, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 153 Answers
Hii
check this link u can instantly know the details u required.
Good Day.
Convert lba to cyl, head, sector
The problem with CYL/HEAD/SECTORS is that disk-drives have gotten *MUCH* too large -- the limited size of each field mean that a new scheme, namely LBA (Logical Block Addressing) had to be created to deal with disk-drives that are 1000 times too large (4 Terabytes versus old 4 Gigabytes).
So, if you have 312,500,000 sectors,
and each sector is 0.5 Kilobytes,
you have 156,250,000 Kbytes,
or 156,250 Mbytes,
or 156 Gigabytes.
Sep 06, 2012 | Western Digital WD1602ABKS 160GB 7200 RPM...
External drive - red light stays on and computer frozen
If the computer is going ballistic when you plug in your external drive that is an indicator that something is fubar with your Seagate drive. And a data retrieval asap is in order.
Remove the drive from your external case and hook it up directly to your regular computer as a slave drive and see if you can get your data off of it. Hopefully its condition will allow your main drive to bootup , then you can go into windows explorer, and transfer all of your needed files to a usb stick or perhaps your main drive if you have the room. It is not uncommon for a drive to be so bad that even its mere presence will not allow your main drive to boot up!!!!!! Not good. In a case like that you might try to install the drive in a docking station and then hook it up to an up and running computer - you might get lucky and get access to its innards. But do not be surprised if you cannot. Hard drives are like humans - they are all destined to die - you just do not know when.
If you have bad sectors on the drive that are responsible for its condition, you might try to run check disk on it to repair the bad sectors but knowing that if it locates and repairs bad sectors the data in the bad sector may not be saved. But anything you save is better than nothing so it is worth the risk. Then after the retrieval you can run a low level format on the drive - this procedure will erase everything on the drive in addition to permanently blocking out any and all bad sectors on the drive. If it works it will be like a brand new drive.
When drives are manufactured nada is perfect and they always have more capacity that the stated amount. When the low level format is run on new drive, the bad sectors are blocked out and replaced by "surplus" sectors so that stated capacity is met.
Ready for some "fun"?
Mar 21, 2017 | Western Digital 320GB MyBook External USB...
What type of drive is st380011a is called
This drive is an Ultra ATA drive. It requires an IDE connection to the motherboard.
Here are the specs:
ST-380011A
Barracuda 7200.7
FORMATTED CAPACITY (GB) __________________80
ACTUATOR TYPE ____________________________VOICE COIL
CYLINDERS __PHYSICAL______________________
HEADS ______PHYSICAL______________________2
DISCS (3.5 in) ___________________________1
MEDIA TYPE _______________________________THIN FILM
HEAD TYPE ________________________________GMR
RECORDING METHOD _________________________EPRML 16/17 ZBR
INTERNAL TRANSFER RATE (Mbytes/sec) ______up to 85.4
SUSTAINED TRANSFER RATE (MB/sec)__________up to 58
EXTERNAL TRANSFER RATE (Mbytes/sec) ______up to 100
PIO/DMA/UDMA MODE (max) __________________4/2/5
SPINDLE SPEED (RPM) ______________________7200
AVERAGE LATENCY (mSEC) ___________________4.16
BUFFER ___________________________________2MB
Read/Write Multiple, Read Look-Ahead,
Multi-Segmented
INTERFACE ________________________________Ultra ATA/100
SECTORS PER DRIVE (LBA mode) _____________156,301,488
TPI (TRACKS PER INCH) ____________________94,600
BPI (KBITS PER INCH) _____________________up to 595,000
AVERAGE ACCESS (ms seek/read/write) ______/8.5/9.5
SINGLE TRACK SEEK (ms seek/read/write) ___/<1.0/<1.2
MAX FULL SEEK (ms seek/read/write) _______//
MTBF (power-on hours) Office _____________600,000
SHOCK (G's, 11ms/2ms):
operating (Read/Write) __________/63
abnormal ________________________
nonoperating ____________________/350
ACOUSTICS (bels)
fluid bearing (typ/max-quiet/max-perf) _<2.2//3.5
POWER DISSIPATION (watts) ________________
POWER REQUIREMENTS: +12V START-UP (amps) _2.8
POWER MANAGEMENT (Watts):
ACTIVE _______________12.5
IDLE _________________7.5
STANDBY (typ/max) ____0.9/
Mar 17, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I need the id info for a quantum lps52, cly--hd--pre--lz--sec--size
P R O D R I V E L P S 5 2 A T QUANTUM NO MORE PRODUCED Native| Translation ------+-----+-----+----- Form 3.5"/SLIMLINE Cylinders 1219| 751| | Capacity form/unform 52/ MB Heads 2| 8| | Seek time / track 17.0/ 5.0 ms Sector/track | 17| | Controller IDE / AT Precompensation Cache/Buffer 64 KB LOOK-AHEAD Landing Zone Data transfer rate 1.750 MB/S int Bytes/Sector 512 4.000 MB/S ext Recording method RLL 2/7 operating | non-operating -------------+-------------- Supply voltage 5/12 V Temperature *C 4 50 | -40 65 Power: sleep W Humidity % 8 85 | 5 95 standby W Altitude km -0.060 3.000| -0.060 12.000 idle 5.5 W Shock g 6 | 60 seek W Rotation RPM 3662 read/write 6.5 W Acoustic dBA 45 spin-up W ECC Bit 48,WITH 11BIT BURST COR MTBF h 60000 Warranty Month 12 Lift/Lock/Park YES Certificates CSA,FCC,IEC380,SDA,TUV,UL4...
Oct 05, 2009 | Maxtor Computers & Internet
What numbers off the HD do I use to set up the CMOS on the mother board under "User" hard drive?
Use automatic detection if it is available; if not use the following:
Size: Usually set automatically depending on the settings for heads, sectors, and cylinders.
Cylinders: The number of cylinders on hard disk. Should be written on drive.
Heads: Number of heads. Should be written on drive.
Write precompensation: Not much used on modern drives. It was used to accomodate drives that had the same number of sectors per track, including both the inner and outer tracks. On SCSI drives
, set this to -1. On IDE drives, it is not necessary to worry about it as it will be determined automatically.
Landing zone: Used for drives that don’t have auto-parking. All modern drives do, so just set to 0.
Sector: Number of sectors per track. It’s often 17 for MFM drives, and 26 for RLL drives.
Jun 26, 2009 | IBM Computers & Internet
Dell optiplex gx110 733mhz won't recognise another hard drive
this time external hard disk drive to you Dell... this Dell optimized for only that 10GB drive..
Jun 17, 2009 | Computers & Internet
Wrong Hard Drive capacity
first you change ribbon data cable which connect hard disk
it may not be supporting more than 32 gb capacity.
first you only connect the only hard disk test for detection
Jul 05, 2008 | Compaq (166361-001) Motherboard
Quantium 10.2 gb fireball CX10A011 specs. ie sectors, mode, etc.
The specifications to enter the information manually, are on top of the harddrive. Kind of hard to discern, huh? That's because harddrive sizes from 6.4GB through 20.4GB are listed on top.
C/H/S = Cylinders/Heads/Sectors
The Quantum Fireball CX10A011 hardrive is a 10.2GB harddrive.
You will see -> C/H/S....10.2 - 16383/16/63 on top.
That is ,
16,383 Cylinders
16 Heads
63 Sectors
As for the 40GB model, it should be similar. If not, come back and post.
Jan 22, 2008 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive Logo
379 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
