Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
NO POWER camera shut off in mnid shutter. battery fully charged, but cleaned all the terminals and then charged again. replaced the time/date battery. and also a new CF card. Once everything was done still no power at all. It will not turn on. Someone told me that it was probably the motor. I have no idea, does anyone have any suggestions
  • grill97 Dec 11, 2007
    I am open to everything and anything. This camera mean a lot to my wife. When she removed the lense there is nothing but a black hole. I could have sworn that you usually see the glass piece, or I may have been wrong. I have been reading, do you think it may be motor or a gear, or a fuse? Do you know how much this possibly could cost to repair? Thanks
    President:
  • 4,402 Answers
I would have to agree sounds like a motor or gear that the motor turns.
Posted on Dec 10, 2007
  • Cary Farah
    Cary Farah Dec 11, 2007
    it could be any of the above, no idea how much it cost to repair.
Camera shuts off when shutter button is pressed.
I'd try replacing the battery first. It is common for a low power battery to not allow the camera's computer to read what it is supposed to do correctly. If the new fully charged battery doesn't fix it, I'd then contact customer service.
Apr 29, 2015 | Canon PowerShot S2 IS Digital Camera
As soon as I turn it on, it shuts back off
Kodak offered no help with this problem and for my camera more than five years old no repair option was available. However, after thinking about this problem a solution was found. Perfectly charged old batteries and new batteries fully charged did not correct the problem. Here is what worked for me: With fully charged battery installed, place closed camera on EasyShare-One camera dock. With the the green light flashing, simultaneously depress both the power on/off button and the shutter button. With both these buttons held down, toggle the capture view switch from an intial down position to up, and then down position.Now release both the power on/off button and the shutter button simultaneously. This whole process takes about 20 seconds. Let the camera remain on the dock until the green light stops flashing. Remove the camera from the dock, open the camera back as usual and the screen will present you with date/time setup. Enter the date and time as required, hit the 'done' icon with the camera pen and the camera will now function normally. Why this works is speculative. However, the idea behind this method is to force a 'reboot' to factory settings by maximising conflicting electronic input signals.
Dr Barry T Rubin
Aug 13, 2010 | Kodak EasyShare One Digital Camera
Canon 40d-pressing the shutter seems to short out the camera.
I recommend that you remove both batteries for ten minutes to get a full reset. you spoke of the main battery. When you open the battery compartment, look at the lower right toward the camera with the LCD facing you.
It is a little hard to see, but will say CR2016 3V. Stick your fingernail under the lip and just pull it out.
As I said I left both batteries out for about 10 minutes.
You will have to re-set the date and time after your done.
Oct 16, 2009 | Canon EOS 40D Digital Camera
Camera wont turn on
This problem is frequently due to either weak/defective batteries or corroded battery terminals inside the camera. Make sure that you have fresh/fully charged batteries in the camera. If the problem persists, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Aug 12, 2009 | Olympus FE-370 Digital Camera
Kodak P850: Pressing the shutter button turns camera off
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
Aug 03, 2009 | Kodak EasyShare P850 Digital Camera
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
DMC Tz3 will not power up. Battery is fully charged. sometimes when it does come on it will not read card and will have to reset date and time.
First remove the SD card in case it is defective itself causing the camera to act funny. Next, your symptoms are indicative of a bad, not fully charged, or intermittent battery contact with camera's contacts.
Clean batt contacts using a clean pencil erasure.
If this doesn't work, measure a fully charged battery's voltage on the battery pos(+) and neg(-) terminals. It should be 4VDC. If less than 3.8, I would be suspicious it is not taking a full charge.
New batteries on ebay are cheap, and would not be a loss since you can always use backup batteries if you get another TZ camera. Or, you could just sell your camera to a repairman in an ebay auction, keeping your batteries and accessories, and buying a used working one with accessories cheap.
Feb 24, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Camera shuts off after one shot
Set the camera to clean ccd mode and carefully remove the lens. If you can't see the ccd but only the shutter then the shutter is sticking. I have this problem when not using the camera regularly. My solution to free the shutter was just to set the camera to long exposure and just keep restarting the camera and taking a photo until the shutter moves. This problem happened from the very first time I had the camera run low on batteries at a few months old but at the time I never checked the shutter and the camera just restarted once and it worked.
Sep 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Kodak easyshare z730
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
May 19, 2008 | Cameras
It wont turn on
Hello
First, you must be certain that your battery pack is still good.
You have to clean all connecting point (between the camera and the batterry) with a dry clean cloth inside the battery pack compartment.
Another think to check, is the date and time battery (dime size battery located inside the battery pack compartment) to remove it, slide the battery case out and change it. Since the battery is install at the factory, it verry possible that there is no more power. At the end of your owner manual, you will find, before troubleshooting section, the way to remove it, it verry easy, no force need it.
A deffective flash card can also cause the problem. Remove also the flash card and replace it by a new one or another one that you have.
When the battery is fully charge, install it along whith the new time and date battery. Leave the camera alone for a couple of hour in order to let the board get some refresment. Try to put it on, if it not work, slide in and out the battery, couple of time, close the compartment and try again.
In many cases, the camera will start and you will have to put the time and date, if the battery (time and date) was warn out. Make sure that your screen is on. You ready to go. :)
Feb 15, 2008 | Canon PowerShot G5 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
42 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
