Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
What is the part # for a drain hose on a KitchenAid dishwasher model KUDI01TJ
    President:
  • KitchenAid Master
  • 1,922 Answers
AP4399659 Whirlpool part number
Posted on Sep 13, 2009
Kudi01tj
do you here a hum noise ? trying putting some water in the unit and strat it to see if the motor is running if that works then you have a problem in the fill components there is also a float in the front corner and it might be stuck up
May 24, 2014 | Dishwashers
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe another model with the same size/layout of the door?
Applianceart.com has stainless steel options for door panels as well as a faux stainless steel that was on HGTV. I'm not sure if the panels they have would fit your model, but their rolls of stainless would definitely help.
Nov 24, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
DISHWASHER NOT CLEANING TOP RACK DISHES
I had the same problem (no water being delivered to the top rack) and found that the chopper assembly was completely blocked. I removed it, washed it, put the whole thing back together. It works like new now.
Note that it is not easy to get to the chopper assembly. I used the "pump and motor parts" diagram on http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208193720.pdf. The inlet protector was especially difficult to get off, but I was able to pry it off to expose and remove the chopper assembly. I cleaned all the parts I removed really well before re-installing.
Jun 16, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
I cant get my dishwasher to turn on, i press the normal cycle and the light flashes 4or5 times and nothing happens, i've unplugged it and tried all of the cycles nothing works
Count the exact number of flashes prior to the pause - this is the error code necessary to diagnose the problem. What is the model number also?
May 13, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Kitchenaid dishwasher
What are you draining into - an air gap to a disposal, air gap to drain, directly to disposal, or directly to drain? How long has this been happening, and have you done any plumbing work recently (new disposal?)
Greg
Jan 27, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
No water coming into dishwaser.
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Jan 02, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Nosiy dishwasher
Refer to the followin solution for a GE dishwasher.  This simple fix may solve your problem too!
http://www.fixya.com/support/t204050-ge_adorda_dishwasher
Aug 14, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Water inlet opening dishwasher kitchenaid
I would like to help you but I really dont know what type of problem you are having. If you couold give a more detailed description of your problem I may be of help to you.
Jul 10, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
66 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
