Question about Honeywell Programmable Thermostat Heater
Replaced battery, now cannot get a/c to work
The screen now says battery low, even tho it didn't say that before. We tried different batteries just in case, brand new, and still says battery low. So we are unable to set the program, or get the a/c to turn on.
  • Richard Johnson PE
    Richard Johnson PE May 11, 2010
    what model thermostat?
  • Donnie Wilson
    Donnie Wilson May 11, 2010
    Is your altinator working?
  • 92 Answers
Sounds like a defective thermostat!
Posted on Sep 12, 2009
  • Nathan Ellsworth Sep 12, 2009
When i try to turn on it keeps sayin low battery even tho i charged all night
Hello Brittany Martin,
It appears that there are quite a few after market retailers that have replacement batteries for your unit
(Creative Zen V Plus 2 GB) for sale...
If your unit was recently purchased ... you should probably consider returning it from whence it came... If however... you have charged it a couple of hundred times... the battery has reached the end of it's life-cycle... (not unlike your cell phone... if you have ever kept one long enough).
Battery replacement services are available...
The batteries are not terribly expensive... some come with complete kits for the BREAK-IT-YOURSELFERS
Al depends if you are a gambler or not... If you have never done electronics before...
First buy SHOULD BE... an anti-static wrist-band
(my favorite topic)...
Everybody always has to start someplace.
Good luck...
http://ebay.com/Creative+Zen+2+GB
Apr 12, 2016 | Creative Zen V Plus 2 Gb Portable Media...
What do i do if my Samsung Galaxy tab 2 isnt charging at all?
try a different USB / Charging cable. If still not resolved, replace the battery.
Oct 19, 2014 | Samsung Galaxy Tablet PC
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
Have a 4-5 yr old Canon S2 IS PowerShot A75 Digital Camera. The batteries are new &/or charged but the camera won't always work reliably - says to change batres. but if I just open the bat. door...
Sometimes, the lower contacts get bent downward after years of use, causing the batteries to ride low in the compartment, and thus making poor contact when the battery door is closed. Try lifting/bending these interior battery contacts upward, so that the batteries ride higher when inserted.
Oct 29, 2011 | Canon PowerShot S2 IS Digital Camera
Help! I have a 2004 Ford Explorer XLT Sport, V8.
try disconecting the battery for about 40min and leave the key in the on position while its disconected, turn off the key and reconnect the battery this will reset the ecu and may help your problem good luck and please rate
Aug 01, 2011 | 2004 Ford Explorer
Hi, my laptop is always plugged into an outlet, so it never has to use the battery. Everyday I come home, tho, it is hibernating and when I turn it back on it says the battery power is extremely low. As...
The battery you are trying to use is faulty you should consider either taking it out of notebook or replacing it, as power if being taken from the socket and the notebook is trying to charge the battery and with a faulty battery may cause harm so yes remove the battery or replace, please rate if i have helped Kronoguy
Jul 07, 2011 | Dell Inspiron 6000 Notebook
Two problems, when the vehicle sits overnight battery dies. battery is 4 yrs old, and test'd alt'nator/battery. no answers as what to do next
this could be one of two problems one ur alternator may not be charging it or has a low charge to it ot two with youre battery being that old its probalbly sulfated by now which means even if youre alnernator is working properly youre battery wont hold the charge try replacing the battery first tho
Feb 15, 2011 | 1996 Ford Bronco
Wont start
is your battery good? headlights nice and brite?
are there any blown fuses? (fuses usually found under dash below steering wheel)
do you hear a clicking noise? does it seem like your battery is low even though you know it is not?
Is your car clicking when you try to start it?
does it make u think your battery is low, but it isnt?
Y
our starter solenoid will click but nothing else when u try to start your car if your starter is not getting enough power from the battery. This can be caused by a low battery, however it can fake you out and seem like that battery was getting weaker and weaker over time even tho what was actually happening was that the grounding cable (black thick wire) going from the battery to the starter or a bolt on something metal under your hood may actually be degrading over time and need replacement.
Fix: #1
test your ground cable with starter cables! put the negative(black) on the battery then the other black end on anything metal that doesnt move and is not painted. also make sure its not in a spot that could loosen and fall into moving parts if the engines starts. Try starting your engine. If it starts you now know that your ground cable is bad. They are about $5 at autozone and 2 bolts to replace. Just follow it from the battery down to where its bolted on.
Dec 30, 2009 | 1997 Chrysler Town & Country
Samsung SCH i760 wont turn Phone on.
My i760 is doing the same thing just hours after seting up page plus service on it .. I hope there is a way to fix this .. Hard reset is not clearing the phone number if your fast you can get into the phone settings befor it shuts right back off i even reset it from phone settings and still no good. has anyone fixed this yet .. or is it something that happens if you use this phone on page plus ..
HELP PLEASE !
May 28, 2009 | Samsung SCH-i760 Smartphone
Heating & Cooling Logo
766 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
