Controller shows drive but with 0 mb. windows once booted doesn't show drive.
  • 2 more comments
  • fstephen Sep 11, 2009
    Yes
    I have a ASUS A7N8X Deluxe MB I'm running XP SP3. I've had this drive only a few weeks and I was going to replace a smaller drive, which I copied to the WD drive. I ran with this drive until I restarted the PC and the drive has not worked since.
    I have tried installing windows again and when booting the BIOS shows the drive but when its time to install the SATA (SCSI) drivers windows install doesn't see the drive. I was hoping for a repair utility. I downloaded a Diag utility from WD an d built a bootable CD but it blows up when it loads.
  • fstephen Sep 12, 2009
    It was formatted at one time but now windows does not see the drive, only the SATA controller it shows 0 MB.
    I tried switching SATA ports and same results. Don't have another PC. I'm sending it to WD for a replacement.
    Thanks
    Steve
  • 13,433 Answers
Is the drive partitioned and formatted? if your still able to use windows, right click on my computer and select manage, you will find my computer or computer from either your desktop or from start menu. In the management window on the left side, click on disk management, you should find the drive there, have a look there what it says there, you could email me a picture or attach one here, anyway my email is
Posted on Sep 11, 2009
  • Ekse Sep 12, 2009
    Drive is probably faulty, try reconnecting the drive to another computer or to another sata port and see if it shows 0M on another port and 0M on another computer. If it does show 0M on both, the drive is definitely faulty.
    warranty check and data recovery services.
    http://support.wdc.com/warranty/index_en...
    I got your email and I see the other comment.
  • 601 Answers
Check if the drive is detected in the BIOS?
Let me know
Thanks
Smith
Doesn't see entire 3TB drives
No. There is a 2TB MBR (Master Boot Record) in Windows.
It needs to formatted / partitioned if new. Type diskmgmt.msc in Search / Run and use the hard drive setup wizard. Highlight the drive and use the refresh icon to initiate wiazard.
You may even have to deleted partition and start from begging. This will cuase data loss. Windows 7 and newer has a dynamic drive option to expand if the partition if not active with the OS.
Dec 31, 2012 | Gateway MB.GAH09.001 Motherboard Desktop...
Hi everyone, I was installing windows xp sp3 on my compaq desktop computer through my hard drive because my computer doesn't recognise cd roms, So I can't install through cd drives. It installed to...
Hi
Have you tried to go into your cmos settings and enable the settings to detect your cd rom
You should be able to use a external cd rom connected through your USB port to load and re-install windows and your drivers if you have the motherboard cd.
The problem is your limited in your options to work from the hard drive but a disk also gives you the option to repair the filing system and replace missing files.
The problem with installing windows on one pc and it not working on another pc is the motherboards are not compatible, and the configuration has to be similar or the same so the hard drive can boot up and communicate between the hardware and software.
Your options are use a CD rom, change your MB or google your problem and hope someone else was able to resolve this issue.
Cheers
Nov 26, 2012 | Computers & Internet
Replaced m/b battery, lost bootup, I think because i can't find a way to enable sata drives. how enable sata drives.
Hi, you can download a manual here:
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#?div=Manual
Here you also find driveres for download.
Here is a youtube video that shows how:
http://www.youtube.com/watch?v=yhKXhu1LFiA
Select first the sata configure the hard drive with windows on
has to be the first one it boots from.
It have probably been added to second when you have reset the bios
And it will not boot.
Hope this will help you.
Aug 19, 2011 | MSI K8N Neo4-F Motherboard
Have an hp pavillion ze2000 that will only detect the hard drive intermittently.Bios will sometimes show the drive and windows will boot. Suddenly windows will BSOD and I have the problem with bios...
First reseat the drive firmly, and see if there is any difference. It is amazing the difference a millimeter will make in getting that driver to stay detected. If reseating does no good, then the MB connection itself is suspect
Sep 04, 2009 | HP Pavilion ze2000 Notebook
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
Toshiba 2 gb flash drive showing 0 disk space
You can only format these drives in mode FAT16 or FAT32.
Try to format it in FAT32 mode and let Windows choose the default sectors for you. This is the better solution.
As I can see, the operating system recognise your drive that mean the correct driver was loaded.
After a new format whith the correct params if your flash drive shows the same thing 0 disk space 0 disk space used, your drive is DEAD.
It happens if you had unplug your flash drive whithout stoping it by cliking on the icon in the notification window (near the clock), the icon is mini drive whith a green arrow. Allways unplug the USB devices by this because you have the +5 voltage on this connector and if you don't do this an arcking effect happens betwen your device and the connector.
Dec 14, 2008 | Toshiba 512MB USB 2.0 High-Speed Flash...
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
12 people viewed this question
jasbo
jasbo
