How to scan
I need all of the steps to scan material into my Mac
How can I recover a PPT file that is unsaved?
Try opening up PPT and going into file>open>recent or something similar. PowerPoint generally has pretty good autosave or recovery options these days (if you have the latest version)
Feb 01, 2018 | The Computers & Internet
Tip
MXF Converter Mac - Convert mxf file to WMV/MOV/AVI/MP4 on Mac OS with Mac MXF...
MXF Converter Mac is an powerful partner for you to convert mxf file which is not compatible with many programs on Mac. You may have problem to play, edit or use mxf format. So are Panasonic HVX200/HPX300 MXF files, P2 MXF files , Canon XF300/XF305 MXF files, Sony EX camera mxf files.
The Material eXchange Format (MXF) is an open file format, targeted at the interchange of audio-visual material with associated data and metadata. MXF is self-contained, holding complete content without need of external material and bundles together video, audio, and programmed data.
As we all know, the P2 MXF format means high quality and huge file size. When recording in AVC-Intra 100 mode, a 64GB P2 card can be filled up in 64 minutes. It takes long time to copy the HD MXF files, and astonishing space to save them. So you will need a MXF Video Converter for Mac to convert mxf file to other format video on Mac so that the mxf can be compatible with other devices like iPod, iPhone, PSP, iMovie, FCP, etc.
MXF Video Converter Mac is the best mac mxf converter for you to convert mxf file to friendly video formats just like avi, wmv, mp4, mov, mpeg, etc for playing on iPad, iPod, iPhone 4, iTunes, PSP, Apple TV, Android Phones, etc so that we can watch our favorite mxf conversion file everywhere. With the excellent mac mxf file converter, convert mxf within several simple steps. MXF Converter Mac is the best partner for camcorders which record AV data as MXF (Material Exchanged File) files with metadata.
on Aug 03, 2010 | Computers & Internet
What is the Best Mac data recovery software, which also offer some free macOS data recovery facility?
There are plenty of Mac data recovery for recovering deleted files from the macOS hard drive. However, only few of them offer 1-2 GB of free data recovery services to its customers.
On the basic of my previous experience in using data recovery software, I suggest you to go for only two of these macOS data recovery software:
1.MyFilesRecovery macOS data recovery software
2.Easeus Mac data recovery
1Best Free Mac Data Recovery Software to Recover Lost Deleted Files EaseUS Data Recovery Wizard Free
Mar 10, 2017 | Best Computers & Internet
Blue screen of death
There is a cure, your safe. Whatever you do, don't trash the mac. Its fixable, but it is to long to explain in this limited space. Here is a link regarding this situation Mac BSOD.
Sep 24, 2013 | Apple Computers & Internet
How to scan
Step #1 - Have the printer powered up and plugged into Mac.Step #2 - Open "System Preferences" and the in the "Hardware" selection select "Print & Fax".Step #3 - Drag down the menu bar on the left side until you reach the bottom were its labeled "Scanners" Step #4 - Select the scanner that you want and began scanning.
Jan 15, 2012 | Canon PIXMA MX330 Office All In One...
When I scan a negative, all I get is a picture of this negative which is useless. I thought that I could get the picture out of the negative that I scanned and save it so that I could get rid of the...
With the scanner you should have received a cd "HP Scanjet 4800 Series HP IMage Zone Software. Mine is version 5.3 for Windows/8.4 for Mac OS v 10.2.
I have this installed on a pc.
When the button on the lid (2nd from left ) is pressed this opens a window HP Scanning.
On this is an option to "Scan Negatives using the TMA (Transparent Materials Adaptor)" Select this and follow any further instructions concerning optons.
Jan 20, 2011 | HP ScanJet 4850 Flatbed Scanner
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
Installing CanoScan Lide 20 / Lide 30 into Mac OS X 10.5.5
I found this scanner at a garage sale today, and had trouble finding this info myself. Finally stumbled upon this site ( http://cadwell.livejournal.com/39545.html )
I'm using it on a Powermac G5 but both the driver and toolbox app say they are univeral binary. Hopefully this gets you up and running too:
CanoScan LiDE 30 on Mac OS X 10.5
This technical help may seem completely out of place on this art blog but after scouring the internet for 3 hours trying to set my 6 year old scanner up on my new MacBook, I found this info half way down a lengthy comments section of a random blog. So I thought I'd post it here (slightly altered) as a message in a bottle to anyone else in need of it.
How to set up CanoScan LiDE 30 on Mac OSX 10.5
STEP 1:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
STEP 2:
Select MAC OS X
STEP 3:
Download BOTH:
LiDE 20/LiDE 30 Scanner Driver Ver. 7.0.1.1aX
(Mac OS X)
lide20lide30n670un676un1240uosx7011aen.dmg
CanoScan Toolbox Ver. 4.1.3.0X
(Mac OS X)
CSTb4130MXE.dmg.gz
STEP 4:
INSTALL CanoScan Toolbox Ver. 4.1.3.0X
STEP 5:
INSTALL LiDE 30 Scanner Driver Ver. 7.0.1.1aX . Make sure Applications>CanoScan Toolbox 4.1>Plug-Ins is selected as the install location.
STEP 6:
You will be asked to RESTART. You should.
STEP 7:
When you run CanoScan you can choose Photoshop as the default program to open the image in once it has scanned. You do not need Photoshop to open using Rosetta for this to work.
NOTE: If you want to scan directly from within Photoshop CS3, you need to copy the driver 'ScanGear CS 7.0X' which is found in Applications>CanoScan Toolbox 4.1>Plug-Ins into the photoshop pluggins folder, Applications> Adobe Photoshop CS3>Plug-Ins>Import/Export. You also need to open photoshop in Rosetta mode. Apple + I on the photoshop icon and select 'Open using Rosetta'. I would not recommend using this method though.
STEP 8:
Go to System Preferences>Accounts>Login Items and remove both of the following:
N067U_ButtonManager.app
N124U_ButtonManager.app
STEP 9:
SCAN.
Feb 15, 2009 | Canon CanoScan LiDE 50 Refurbished Scanner
117 people viewed this question
k24674
jasbo
jasbo
