Question about Canon PIXMA MP830 All-In-One InkJet Printer
I replaced an ink cartridge and am getting a 5100 error code
The solutions on the Canon website do not work.
  • Craig Gillette
    Craig Gillette May 11, 2010
    What problem or error are you having?
  • 4,041 Answers
Hi Yes you can try clean.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Error 5100 appears on lcd when turning it on. How do I fix?
Try removing and reseating the ink cartridges. If that does not work try replacing the cartridges with genuine Canon ink cartridges. This should alleviate your issue as error 5100 is due to cartridge failure of some sort.
Mar 01, 2011 | Canon PIXMA MP610 InkJet Printer
My canon mp160 got a error 5100 or E2. I have tried several solution: uninstall and reinstall the driver, reset the printer, shake the ink cartridge but still it won't work. Please help..
E2-2 = No paper (ASF) and E22 = Carriage error
steps from canon website 1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP160 may require repair
if you need further assistance please let me know, Thanks midwest-tek
Aug 31, 2010 | Canon PIXMA MP160 All-In-One InkJet...
HI I HAVE A CANON MX 320 MULTIFUCTION MACHINE, THE INK CARTRIDGES HAVE BEEN REPLACED BUT THE SCREEN KEEPS SAYING PRINTER ERROR HAS OCCURED 5100, HAT DO I DO TO FIX
5100 error means a Carriage Home Position Error.
Just make sure you remove the plastic strip covering the print head and the contact copper of the ink cartridge before you insert it to the cartridge holder.
Other possible solutions is that the cartridge is not properly seated on the carriage or cartridge holder. Once it is not properly seated the cover of the cartridge holder usually hit when it moves.
You may also clean the contact copper of the ink cartridge using an soft cloth or cotton moistened with alcohol to clean the surface. Please avoid touching the surface by your fingers.
Jun 23, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Canon Pixma MP110 - Error 5100, cartridge jammed, press OK. But this doesnt fix the problem, any ideas? Many thanks. Happens every time I dont use printer for a while & usually replacing the ink...
Hi You can Try
seen lots of this errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp180
I had this problem. Removed both ink cartridges and carefully wiped the contacts and print nozzles with a tissue. Re-inserted cartridges and printer now works perfectly.
Good Luck.
Feb 20, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error message UO51
Are you using official Cannon cartridges or "ink refill" cartridges? Did you reset your ink levels in the software?
Jan 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Nov 12, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
